- Jul 5, 2001
26.3 Beta is better than 26.2 Public Release.My 15 Pro battery on 26.2 is horrible compared to iOS 18. I replaced my battery at Genius bar because I thought the battery is dying at 83%. But even after replacing the battery, I still find the battery to be bad. Therefore, I have turned on the reduce transparency which helps to smoothed the UI and slightly better battery life.
I hope they fix the battery drain.
Nice. Can’t wait for the public release to resolve my battery issues.26.3 Beta is better than 26.2 Public Release.
Going by Apple standards, public release might screw your battery insteadNice. Can’t wait for the public release to resolve my battery issues.
backup and restore can sometimes work wondersMy 15 Pro battery on 26.2 is horrible compared to iOS 18. I replaced my battery at Genius bar because I thought the battery is dying at 83%. But even after replacing the battery, I still find the battery to be bad. Therefore, I have turned on the reduce transparency which helps to smoothed the UI and slightly better battery life.
already did that.backup and restore can sometimes work wonders
