Pro version.. during PO stage not now tho...This is not the Pro la right...
Very good deal ...Pre order lowest prices... I got mine at $1119 and another 5% SMRT card rebate.... Nett $1063.05...
Yeah it's the pro, I'm one of those who got it at that price from metapod. And haven't even factored in the Cashback coin from mari credit card.This is not the Pro la right...
not many people buy the non-pro so feedback will be lesser. if you want to compare, check the gsmarena page, there you can compare the batt life tested against other phones which you're familiar with and that'll give you a gauge.For the Non Pro, any update on how good the battery life is?
looks weird, i hope this isn't real.https://www.gsmarena.com/oppo_find_x9_ultras_back_showcased_in_new_images-news-71219.php
Oppo Find X9 ultra leaked images.
no such issue. u tried installing another sms app?I have this issue with sms otp from banks. It doesn't come in till I reboot the phone. Any faced the same issue? Any remedy? I have cleared cache on the messaging app. Still the same.
Are you on 5G or recently change telco?Any faced the same issue?
I tried but also couldn't receive. Needed to reboot. I'm using the default Oppo sms app.no such issue. u tried installing another sms app?
another test u could do is ask your friend/wife sms u from another phone and see if u get it immediately. if u do then it sounds like the bank's problem.
I'm on 5G and same telco since beginning.Are you on 5G or recently change telco?
Try downgrading to 4G only, basically force it to only use 4G and your SMS issue should be solved
If you just changed telco, give it a few more days for this problem to resolve itself
Mine only shows 5G. Never seen 5G+ before.Anyone has 5G+ logo on their X9 Pro ?
Using MAXX 5G sim card here. I have 4G+ but not 5G+. just 5G
Same SIM card on XM 14T Pro has 5G+ logo.
dun buy liao , wait april or may for x9 ultra liaoStill worth to hoot X9 Pro? I still contemplating to buy hahaha
