Hi, im moving into my new bto and am planning to get M1 6gbps with tplink BE805. will placing the router at the red spot be able to cover the whole house?
or is it better to have 2 router set-up? 1 in db box, 1 at red spot?
Signal check and speed test, for the router usually the techs are kind enough to help you set it up, like setting wifi name and passwordsis that a speedtest ? They do it directly from ONT, right ? I don't need to set up my router first, right ?
4rm5rm? The router location is good. Should not be a problem.
yup new BTO. i was initially thinking of using mesh setup (1 unit at DB, 1 unit at BR2), but i saw some comments saying mesh wouldn't work well in a small hdb unit and a single router is sufficientIf it's a new BTO, high chance you have provisions for individual ethernet ports in each room. You can just have the ONT at the DB BOX, then the router in your room, or better, ONT and Router in the DB BOX, then additional WIRED MESH access points to each room (or room 2 Only), then add more wired units as needed.
No need mesh. Mine is 5rm and totally no problem with WiFi.4rm
yup new BTO. i was initially thinking of using mesh setup (1 unit at DB, 1 unit at BR2), but i saw some comments saying mesh wouldn't work well in a small hdb unit and a single router is sufficient![]()
Get whatever is the cheapest. If 10gb is $29.90, grab. If comes with free router even better. Dun mind the speed, even if u dun need it or ur current hardware dun support. The cheaper the better is what u should aim for.I have up to May for my contract to expire and eligible for recontract. Thinking of getting the 3GB for $32/-. Should wait for Comex or IT Show to renew better ?
i see... thanks for sharing. i might try using 1 first, if needed then i'll buy another router off carousellWhy will it not work well in a small hdb unit?
Having more access point is actually good, especially with high speed connection...
Long time ago, it's common practice to have 2 separate SID (wifi name) to separate 5ghz and 2.4 ghz. but with the latest trend, it is now combined into one WIFI Name with the access point deciding which one is best for you based on your location. (aka Band Steering) so yeah by default you'll still get a good signal even if you are in some nook places because the access point has switched your connection to the 2.4 ghz, which is long range and more permeable to walls and obstacle.
who say one...4rm
Hey Boomer!! time to upgrade!That is correct, because now you are limited to the speed of your router.
You are only as fast as the slowest port.
Also remember, there are older CAT cables that can only support 1gbps, so even if you have 2 10gbps port, it’s the cat cable that decides
ONT: Nice meeting you Router, i can do 10gbps
Router: Sorry ONT i can only do 2.5gbps
ONT: It’s okay, let’s do 2.5gbps then
ONT/Router: Hey CAT cable, you can do 2.5gbps right?
CAT: I’m only CAT5E, at most i can do 1gbps
Then they all agree to do 1gbps.
in reality though, before the ont and router talk, it’s the cat cable who carries the message of negotiation, and if you are asking a boomer CAT cable to carry a genZ message, the cat cable may not be able to deliver that message correctly, so the genz ont and router will try to adjust their “language” until the boomer CAT cable can understand and deliver the correct one. Once they figure out the language the CAT cable can understand and deliver, they stick to that
Hey Boomer!! time to upgrade!![]()
It's up to you.just installed the new router with 6Gbps plan. the technician asked if i wanted to combine all 3 frequencies together, he said it is recommended to. Previously my 2.4Ghz and 5Ghz were separate frequencies which I can choose between. Should I combine or separate the 3 frequencies?
