Oppo Find X9 Series
chari-men
Bro, that's not case, that's the protective thing to conceal the actual look/design of the phone while they bring it out for testing or under NDA.
Ah i see.. but it shud be largely similar to a black silicon case?? Why oppo keep changing their design matrix sia...
shichuanhua
Phone keep getting heat up these few days. Dk what's going on . Not sure if it's due to bilibili app
rainbow99
Just keep the wifi on then. Tbh it doesnt make sense if u manual off the wifi and u want to auto connect in OFF position. It defeat the purpose of the OFF button.
Thanks, it used to work for my S24U. I usually off WiFi at workplace and my S24U will auto turn on and connect to WiFi when I reach home. Was wondering why it doesn't work for Oppo after switching over. Just curious if it's an OS limitation or my own incorrect settings.
therat
is it after the new update?
I do feel it. Phone getting heat up while playing game.
After restart the phone, the temperature drop. even while playing game
shichuanhua
Yeah seems to be after the update, more likely to get heat up
limmk
A fresh leak shows real-life images of the Oppo Find X9 Ultra with a huge circular camera module and possibly a 300mm telephoto extender. The flagship phone, which will come out in March, will have a 200MP main camera, dual periscope lenses, and a 7,000mAh+ battery. It will be powered by the Snapdragon 8 Elite Gen 5.
Oppo has done something that very few other companies have been able to do. They’ve established their flagship devices among the best in the industry. In fact, many consider the Oppo Find X9 Pro (Review) to be the best Android phone of 2025 thanks to its impressive photography capabilities, performance, and battery life. That said, the company isn’t finished with this lineup yet. A new leak offers what appear to be real images of the upcoming Oppo Find X9 Ultra.
The images, shared by a Weibo user, show the device hidden inside a “confidentiality case” to mask its final aesthetic. However, the massive circular camera module on the back is impossible to ignore. This design choice confirms that Oppo is doubling down on its reputation as a leader in mobile imaging.
Real-world images of the Oppo Find X9 Ultra in new leaks​
The standard Find X9 and Pro models use the already powerful Dimensity 9500 flagship SoC. But the Ultra variant is expected to feature the cutting-edge Snapdragon 8 Elite Gen 5. This processing power will support a stunning 6.82-inch AMOLED display with 2K resolution and a 120Hz refresh rate. To keep this high-performance machine running, rumors point to a massive battery of at least 7,000mAh. The firm could also implement super-fast 80W wired charging.
Oppo Find X9 Ultra real life images 2
Oppo Find X9 Ultra real life images 1
The real star of the show is the quad-camera setup. Leaks suggest a main 200MP Sony LYT-901 sensor, designed to capture an incredible amount of light for cleaner, more detailed photos. This is reportedly complemented by a versatile array of lenses, including a 50MP ultra-wide and two distinct periscope telephoto cameras. One telephoto lens reportedly offers 3x optical zoom with a 200MP sensor, while the other provides a native 10x optical zoom for extreme distance.
Like the standard and Pro variants, the Oppo Find X9 Ultra will likely have its own professional teleconverter kit. This external attachment could extend the phone’s reach to a 300mm focal length, currently the highest in the industry. Images of a prototype even show a dedicated camera grip and physical buttons, suggesting the phone can transform into a legitimate pocket-sized DSLR.
Launch timeline​
Oppo typically reveals its flagships in China first, with a local launch expected in March. Global fans shouldn’t have to wait much longer, though. The Find X9 Ultra will likely hit international markets during the second quarter of the year. Finally, your handset would be available in classic shades like black, brown, and orange.
