[OFFICIAL] Singtel's GOMO discussion thread
mun
my oppo find x9 pro on GOMO is now showing Vo5G instead of VoLTE. is it considered on 5G SA?
Fellowes
@Fellowes have you started receiving 5G SA signal?
I port out before GOMO sent me the data upsize, now using $7.90 M1 MAXX 4G then next month renew to $12 M1 MAXX 5G to try out M1 5G SA network for 6 months, save $38 as compared to GOMO 5G+ Value during this period.
Will port in back to GOMO $18.33 5G+ Value plan after August but depends on its promotion, hope by then even more improvement in terms of roaming data.
gapboy
so far enjoying maxx 4g?
SojIrOu
Good to know they are starting to migrate users to SA but sadly still on 5G NSA on my phone. Been testing the Zero1 5G SA vs GOMO 5G NSA over the last week and not noticing any speed differences but hopefully can get better phone battery life with SA.
Food_Lover
My fiancee used GOMO for 2 years and has been on 5G NSA since then.
Does anyone receive any SMS from GOMO to swap SIM card for 5G SA?
gapboy
My friend is on Gomo told me his 5g plans do not require to change SIM I believe still on NSA till further notice on Gomo
STKatsuCurry
Your friend should change the sim since 5G SA is already launched on GOMO
A few of my friends have received the SMS to switch, not me as I did it earlier before they send the SMS
Food_Lover
Thanks. May i know where is the collection venue?
Only via Gomo App
More info here. The 31 Jan 2026 date for free 5G+ physical SIM card upgrade may be extended as per the reports here in this Gomo thread.
https://www.singtel.com/personal/products-services/mobile/info/switch-5g-plus/gomo-customers
Switch your SIM in a few simple steps:​
Step 1
Log in to your GOMO app
via your email address.
Step 2
Select Me > Request new SIM.
Step 3
Pick your SIM type:
eSIM (recommended) or physical SIM card.
Make sure you have an eSIM-compatible device and we'll send the eSIM details to your email.
If you’re looking to switch to a physical SIM card, do so before 31 Jan ‘26 to avoid SIM change charges!
FatalethaL
Just spoke to GOMO chat rep. He mentioned GOMO is still on NSA, not SA.
On the other hand, I found that I missed the SMS from GOMO to switch from 4G to 5G+ SIM card for free before 31 Jan 2026.
To keep enjoying Singtel 5G+ connectivity & its full benefits, switch your 4G SIM to a 5G+ eSIM by 31 Jan '26 to avoid SIM change charges.
SIM upgrade is only applicable for this mobile number. For questions, simply visit Zenmo and type <GOMO5GSIM> to find out more
This got me thinking - 4G SIM card can use 5G NSA ah? All along I have been subscribed to 5G plan.
Anyways I got curious and requested new SIM (physical), and it showed $0 replacement cost/fee. Might as well! I applied and now waiting for collection.
STKatsuCurry
There are some of us that are on Gomo 5G SA. Think the CSOs are not updated on this
sad_xiaoxin
The deployment usually takes some time, as per the reports from the Zym thread.
Seems like its in batches..
Only one line has 5G SA after forcing it in android settings and doing an airplane mode on and off.
My other 2 line don’t have it even using the same method or rebooting.
Strangely its the line that registered later then the 2 line..
Maybe SingTel enabled to newer registration then to later?
STKatsuCurry
Cannot be, I signed up for Gomo in August 2024, replaced SIM in January this year
