Help with SingTel Fibre 500mbps
torrent06
I’ve been on a legacy 500mbps plan (I think the router is wifi 5) without contract. Recently I have been having intermittent loss of connection and the technician who came down did not do anything other than to look at the error message I got before saying it’s a router problem. SingTel will not provide me with a free replacement router unless I recontract at a higher price. Is there any issue if I buy a SingTel router from other people and replace on my own? I also thought of getting another router of perhaps better quality as SingTel routers seem to spoil every few years but it seems I will need SingTel to enable bridge mode which is no longer available?
Can I buy Wifi 6 Singtel routers to work with my current modem and plan and will I need to get SingTel to change some settings at its end? Are there other security issues I should consider?
Asus80
no need u can do urself just plug N play. i have one singtel wifi 6 Router also
Mancunian2
how much you paying singtel for 500 mbps?
you can find new isp, 3-5 gbps for under $30 these days
keenklee
IMHO.
My household is on Singtel 500Mbps. Recently after >5 years, the ONT ac adaptor died and the router died because it was turned off for quite a while. I just use an old Asus RT-AC86U.
86technie
Think it this way even if you pay higher.
When you recontract at least you get a free router.
I will not recommend Singtel due to the issues they have including bad customer service.
Try go with M1 or Starhub less than $40 with free WIFI 7 router.
If you buy second router there will be few things to take note:
- Need to reset the router most when sell the router they never reset.
Unless brand new sealed than no need.
- If used set may failed or spoil.
- Need Singtel profile than the router can work.
Is up to you which you decide.
Brand new router depends on your budget.
If you want the cheapest and best will be Dlink X3000Z around $60.
https://www.challenger.sg/products/...riekKUeJ1ILdyIp69KZ_rJ&variant=41678103904331
This router does look like Asus router you are using.
The good thing about this router is plug and play.
Just plug in and it will setup by itself.
If you want to change the WIFI SSID you just need to log in and change yourself.
For budget router I will recommend Dlink.
green72
Just get a 3rd party dc power supply online for the ONT. Just ensure voltage same and the barrel plug same size.
My ONT power supply oso died a couple of years ago. Did what I mentioned.
For router, go find a new and cheap asus routers on platform like carousell. Many dump these Wifi 7 Asus routers when they sign up to a new ISP. Probably theirs are of high-end models so dump these away to offset their sign ups.
torrent06
My parent still wants to maintain the analogue homeline and it is included in the price if I stay with SingTel broadband. If I get Dlink, how do I set up the SingTel profile?
86technie
Like I shared that Dlink if you are interested is Plug and play.
Don't need to do anything except if you want to change the WIFI name and password
than you need to log in.
Else this is the by far the cheapest and simplest router you can get.
If you are using Singtel ONT, it is not plug and play for 3rd party routers. But it is not difficult if you buy those with SingTel VLAN support, like Asus and TP-Link.
SingTel WiFi 6 routers are plug and play with either Singtel ONT or ONR, but they are either EOLed or soon to be EOLed, so you should not go with them.
Reference for Asus and TP-Link router: you need to select SingTel VLAN profile.
The following are two Cheap and pretty decent one below S$100 (or less than S$80 if you find the right seller). They are cheap because M1 bundles them free with M1 3Gbps plan. They are way better than the lousy Singtel WiFi 6 routers. But you can get cheaper Asus/TP-Link ones as well if you want to save more. For example, second hand units of Archer BE230 and RT-BE58U may well be cheaper than S$50.
Asus RT-BE58U WiFi 7 BE3600 router, dumped by M1 users.
How to set up VLAN profile for Singtel ONT users?
https://www.asus.com/sg/support/faq/1044897/
TP-Link Archer BE230 WiFi 7 BE3600 rotuer, dumped by M1 users.
https://www.tp-link.com/sg/support/faq/3836/
How much is your current pricing for the 500 Mbps plan?
You can do the calculation to see if it makes sense to upgrade to 3Gbps or 5Gbps plan and then pay for the Analog phone.
Some users are able to get S$29.90 per month pricing with Singtel 3Gbps or 5Gbps recontract offer, with free HB611-SGST router.
Analog phone is at about S$10 per month.
https://www.singtel.com/personal/products-services/more/telephony-services/home-line
Example Singtel 5Gbps recontract offer: you may or may not get this offer, YMMV.
https://www.singtel.com/personal/products-services/broadband/eform/recon-edm/5gbps
5Gbps Enhanced Plan at $29.90/mth (U.P. $70.90/mth)
Comes with 1 x Singtel WiFi 7 (TP-Link BE11000) Router
If you are keen on the above combination, you may want to check out Singtel thread below to see how people manage to get the above offer.
https://forums.hardwarezone.com.sg/threads/singtel-3gbps-5gbps-10-gbps-enhanced.7030365/
The other option is of couse to move out of Singtel but pay for Singtel Analog phone. You may need to talk to Singtel to debundle the analog phone service first from your legacy Singtel 500 Mbps plan.
Then you can go with either M1 3Gbps (S$32.90 per month with free WiFi 7 router) or Starhub 3Gbps/5Gbps at about S$29.55 per month with free router. You can check out the sticky thread for the latest promotions.
https://forums.hardwarezone.com.sg/...sg-isp-comparison-latest-promo-deals.6665380/
The following 5Gbps offer from Starhub may be the best now.
As per the report from a forum member, you can contact the famous Selina (search the forum for her contact info) to get the following offer for StarHub Fibre Internet service.
1) 5Gbps Broadband @$29.55/mth
- 1x Free TP-Link HB710 WiFi 7 router
- Free $100 Shopping Vouchers --> upgraded to S$150 voucher later
2) 10Gbps Broadband @$44.49/mth
-1x Free TP-Link EB810v WiFi 7 router
- Free $250 Shopping Vouchers
3) 10Gbps Broadband @$33.59/mth
-1x Free TP-Link HB710 WiFi 7 router
-No Voucher
Installation and activation fess waived
*24 months contract
Note: she is famous since Dec 2024.
You can WA her at this no. 81161630, her name is Selina
TP Link EBV 810 is $15 monthly for 24 months.
Activation and installation fee are waive according to her
torrent06
Hi Xiaofan
I’m paying $29.90 currently. They offered me a higher rate to recontract. I prefer not to recontract as I will be charged a much higher rate once the contract expires and I don’t renew (no certainty what the recontract rates will be by then and I don’t fancy having to call in to bargain about the rates). The technician brought a Huawei HG8240T5 during the visit. Is that also EOL in terms of security updates?
Hi Xiaofan
That is an ONR. It is a wired router without wireless function.
Power users will avoid ONR. But in your case it may well be okay for you. You still need a wireless AP to give you the wireless function.
hwsstx
SIMBA Broadband - $0.99 New Sign-ups promotion
You may be interested...
https://simba.sg/6yearsstrong
SIMBA 6 Years Strong Event - Terms & Conditions
General Terms & Conditions
  • All promotions are valid only within the promotional period as stated for each specific offer.
  • Free gifts, promotional discounts, and other promotional items are available for a limited time only as specified during the event.
  • Promotions, discounts, free credits, and gifts are non-transferable, non-refundable, and cannot be exchanged for cash or other products unless otherwise stated.
  • SIMBA reserves the right to vary, amend substitute, or withdraw any promotion at its sole discretion without prior notice.
  • Promotional deals, gifts, and prices are valid while stocks last and on a first-come, first served basis, unless otherwise specified.
  • SIMBA shall, at its discretion and on a while stocks last basis, give a voucher booklet to any person who participates in any SIMBA 6 Years Strong Event promotion.
  • SIMBA reserves the right to modify, suspend, or cancel any Promotion at any time without liability, including in the case of suspected abuse or violation by any customer, in SIMBA's own discretion.
Mobile Promotion
  • SIMBA credits can only be credited into a SIMBA wallet of a SIMBA phone number with an active subscription. If the credit is made to a SIMBA wallet of an inactive SIMBA phone number, such credit will be forfeited immediately and the customer agrees to the forfeiture without recourse.
Port-in Promotion
  • The promotional period for the port-in promotion is 5 March 2026 to 8 March 2026. This promotion can only be redeemed at the SIMBA 6 Years Strong Event held at Marina Square.
  • $20 SIMBA credits will be awarded to all persons who submit their port in request within the promotional period, and the port in to SIMBA is completed before 13 March 2026, 23:59h
  • Receive a voucher booklet with every transaction.
  • This promotion is applicable for all SIMBA postpaid and prepaid mobile plans, except for Business plans. The $20 SIMBA credits will be credited into the subscriber's SIMBA wallet by 20 March 2026, 23:59h.
  • Credits cannot be exchanged for cash or other gifts. SIMBA reserves the right to amend these terms and conditions without prior notice.
  • Other terms and conditions apply.
Recharge Promotion
  • The promotional period for the Recharge promotion is 5 March 2026 to 8 March 2026. This promotion can only be redeemed exclusively at SIMBA 6 Years Strong Event.
  • $20 SIMBA credits and a voucher booklet will be awarded to all subscribers who recharge $20 into their SIMBA wallet. The promotional credits will be credited into the SIMBA wallet where the eligible recharge was made to. Each SIMBA mobile number is eligible to a maximum of $180 recharge.
  • The promotional period for the SIMBA Broadband - $0.99 New Sign-ups promotion is 5 March 2026 to 8 March 2026. This promotion can only be redeemed at SIMBA 6 Years Strong Event.
  • Customers who sign up for a new 2-year SIMBA 10Gbps Broadband plan within the promotional period will enjoy a $29 discount on their first 30-day subscription. They will be charged $29.99 per 30-day billing cycle for the subsequent billing cycles.
  • This promotion cannot be combined or stacked with any other promotion, unless otherwise stated.
  • This promotional discount is applicable on a “per sign-up” basis and is not transferable, refundable or exchangeable for cash.
  • Other terms and conditions apply. For SIMBA Broadband 10Gbps Terms, please refer to www.simba.sg/broadband.
SIMBA 6 Years Strong Event Exclusive Deals – Grab Bags Sale
  • The promotional period for the Grab Bags Sale is 5 March 2026 to 8 March 2026.
  • This promotion is available exclusively at the SIMBA 6 Years Strong Event.
  • Grab Bags are available for customer self-selection, subject to availability at the point of purchase.
  • Each Grab Bag is pre-packed with a random assortment of items, and customers are not permitted to select specific contents.
  • Items in the Grab Bags selected by the customer are not exchangeable with SIMBA, refundable, or redeemable for cash.
  • Grab Bags are available in limited quantities and strictly while stocks last.
  • Receive a voucher booklet with a grab bag purchased.
SIMBA 6 Years Strong Event - Screen Protector Sale & Installation Promotion
  • The promotional period for the Screen Protector Sale & Installation Promotion is 5 March 2026 to 8 March 2026.
  • Screen protectors are sold at a promotional price during the campaign period, while stocks last.
  • Free Screen Protector and Installation Promotion:
  • Customers with the applicable voucher can redeem a free mobile phone screen protector and installation service during the promotional period.
  • The use of the free installation service is the option of the customer who redeems this promotion. SIMBA reserves the right to determine installation availability based on manpower capacity at the point of redemption.
  • SIMBA does not guarantee the availability of a mobile phone screen protector for the customer’s mobile phone. In the event that there is no suitable mobile phone screen protector due to stock availability or fitness, the customer’s redemption is immediately forfeit, and the forfeited redemption will not be substitutable for cash or cash in kind.
  • SIMBA reserves the right to amend or withdraw the promotion at any time without prior notice.
  • No refunds or exchanges are allowed for promotional items.
SIMBA 6 Years Strong Event Voucher – Tote bag and Iron-on Sticker Pack Redemption
  • Redemption of the tote bag and iron-on Sticker Pack is valid from 5 March 2026 to 8 March 2026.
  • The redemption is available exclusively at the SIMBA 6 Years Strong Event.
  • Customers must present the official voucher at the point of redemption.
  • Each coupon is only valid for one redemption.
  • One Iron-on Sticker Pack will be issued per valid voucher
  • Iron-on Sticker Packs are not exchangeable, refundable, or redeemable for cash.
SIMBA 6 Years Strong Event Freebie – Gachapon Spin
  • Redemption of the free gachapon spin is valid from 5 March 2026 to 8 March 2026.
  • The redemption is available exclusively at the SIMBA 6th Anniversary Event.
  • Customers must present the official free gachapon spin coupon at the point of redemption.
  • Each coupon is valid for one spin only.
  • Prizes are dispensed on a random basis.
  • Prizes are non-exchangeable, non-refundable, and not redeemable for cash.
  • If the Gachapon machine malfunctions, SIMBA reserves the right to substitute the prize-drawing mechanism at our discretion.
  • Redemptions are strictly while stocks last.
  • Other terms & conditions apply.
SIMBA 6 Years Strong Event - Photo Contest
  • Only participants who are physically present at the SIMBA 6th Anniversary Event during the Promotion Period may participate in this contest
  • Participants must have a valid public Instagram account at the time of participation. To receive one (1) additional Gachapon spin, participants must:
  • Take a photo at the designated photowall;
  • Upload the photo to their personal Instagram account; and
  • Include the official event hashtag “#SIMBA6YearsStrong” in the caption.
  • The Instagram post must be set to “Public” at the time of verification, and must not contain content that is unlawful, defamatory, obscene, discriminatory, or otherwise inappropriate.
  • Participants must present the posted content to the SIMBA staff for verification before receiving the additional spin.
  • SIMBA reserves the right to refuse participation or disqualify any post that does not comply with these Terms.
  • By participating, participants grant SIMBA a non-exclusive, royalty-free, worldwide license to repost, share, and use the submitted photo for marketing and promotional purposes across social media and other channels, without further compensation.
  • Participants confirm that they have obtained consent from any identifiable individuals featured in the photo.
  • This contest is in no way sponsored, endorsed, administered by, or associated with Instagram or Meta. Participants release Instagram and Meta from any responsibility related to this contest.
  • SIMBA’s decision on all matters relating to this contest shall be final. SIMBA reserves the right to amend the terms of this contest without prior notice.
torrent06
So you have the old SingTel Mesh router and the super old Aztech.
Both are EOLed without further security updates.
You may want to change to a new one as they will pose great security threat to your home network.
Anyway, what was spoiled in the end? ZTE ONT spoiled? SingTel replaced the ZTE ONT with Huawei ONR?
suuhhc
I remember someone mentioned before Singtel can change new set for out of contact customer if u willing to pay for it instead of re-contract (re-contract then free). Maybe u can ask Singtel about it if u don't mind paying for the replacement, surely will be more expensive than getting one yourself but u don't have to go thru all those troubles.
