https://sg.shp.ee/wBWjVBFr
spigen case don't seems will wobble
The link you provided is for Ringke case for S23 U.
NNNPNT
alot brands are working fine including thisChargers capable of SFC 3.0 Charging
Prolink 200W charger GD-520001 (Discontinued)
Essager QU GaN X 100w Charger
UGreen 65W GaN Charger Universal Travel Adapter
NOT capable of SFC 3.0 Charging
Prolink 65W GaN Fast Charge 3 port Universal
Cable
Essanger 100w USB C
Anyone bought this case, what is the thickness on that camera portion? Really dislike the phone wibbling on flat surface but also dislike the phone looks too thick after putting on case.Guess this case also will not wobble!
Thanks for sharing. Thought to compile list cos I was surprised Prolink 65w travel adapter had no SFC 3.0. It's my favourite travel charger. But UGreen 65W travel adapter has SFC 3.0. Both 65W, both travelalot brands are working fine including this
I'm using it now. I can help. Measure thickness from where to where?Anyone bought this case, what is the thickness on that camera portion? Really dislike the phone wibbling on flat surface but also dislike the phone looks too thick after putting on case.
This TQVMI'm using it now. I can help. Measure thickness from where to where?
About 1.4cmThis TQVM
Btw the cover seems to be able to remove out right according to the Shop pictures?
Alright just 1mm thicker than the case I am having nowAbout 1.4cm
No idea.. I don't see a way though...
But my previous Nillkin of this type, the cover dropped out by itself after 1.5 years
Anyone got any comment for Samsung Silicone Case? Need a case when I go to gym.
- Easy to put on and take off?
- Feels secure enough to drop from waist height?
Sibei sian, I always buy Samsung Leather/Alcantara Case, but this year they didn't make one.
The slide cover can be easily removed and put on back if wanted to. Dislike the need to slide the cover every time when want to use the camera or as torch light. Now with this case the phone no longer will wobble when place on a flat surface.About 1.4cm
Then buy this case for what siaThe slide cover can be easily removed and put on back if wanted to. Dislike the need to slide the cover every time when want to use the camera or as torch light. Now with this case the phone no longer will wobble when place on a flat surface.
Phone won't wobble when place on flat surface when typing. Of course some will prefer to cover the camera.Then buy this case for what sia![]()
Thanks for sharing. Slide all the way to the end and exert some strength and it'll pop out?The slide cover can be easily removed and put on back if wanted to. Dislike the need to slide the cover every time when want to use the camera or as torch light. Now with this case the phone no longer will wobble when place on a flat surface.
exp option Whitestone have AR as well.So.. those of you who use the official Samsung film SP, do you always get a flawless install?
My first install already had a tiny bit of dust stuck to the SP despite me triple-checking before sliding the film over. Silly me.. decided to lift up the SP and use a dust sticker to remove it. That's it. Made a total mess. I know this would have worked well on a glass.
The film's AR properties and thinness is really good, but I've got my SmartDevil waiting for that flawless install too. At a dilemma now. Thinking of using this messed up film first, then try the 2nd piece. If still messed up, I'll go for glass.
Also, is there any glass which has the EXACT same AR properties as the samsung film??
SmartDevil AR isn't it unfortunately.
Slide the cover until the end and slightly bend one corner of the cover and it will pop out. Do the same on the other corner and the whole cover will come out.Thanks for sharing. Slide all the way to the end and exert some strength and it'll pop out?
the ringke case fits well with the AR tempered glass9m
Let me know how is the fit of the Screen Protector and case. Just worried that some cases may lift the SP.
