Oppo Find N6
chari-men
the colors very fugly zzz...
BradenHeat
seems like price went up by 1k rmb... i wonder reach sg how much liao lol..
Likely 2.5, or higher, because of the oil pricing .
those going china, just buy there bah.... regardless gonna use or not, still will huat because people importing here will still get a surcharge due to the transport fees going up
and i doubt vivo will allow the ultra for this batch to go international.
OnePunch!!
Jokes aside,
- Echo Equalizer is a must
helps with the volume and sound , gives you eargasims if you have something of a Airpods pro 2/ Sonys/ Headphones etc.
- MagSafe case, or with ring is a must
--> those who want to extend the "creaseless-ness" life , get a stand that ive shown in one of the earlier posts, open it and magsafe on the Stand.
--> not sure if theres a app to create table side clock for it .
- all oppo find n6 comes with inner and outer screen protector, is good , just dont remove until 2 months later when theres more tested and reviewed batches or even
@tkte_85
mentioned place.
- Brave web browser with playlist in flags + adblocker
--> cavat it cannot split screen, so you need another web browser to actual do the spliting
- Lazada split screen bug can be off set by one of the developer settings, found.
--> Enable non-resizable in muti-window
--Battery life relateed stuff, just disable the social apps and chinese ones first before redoing the whole thing
---> might even be better to enable, Smart MOde , rather than restrict background acitivity .
-- Copy image words to text, have to install the circle to search function app.
--> Oppo does not have native image words in photos to text capture .
-- Install o+ connect app
--> allows you to remote either way [phone to laptop , laptop to phone ]
--> fastest transfer of photos, for me as a macOS user with icloud 2tb.
--> allows pairing via bluetooth to my work iPhone , so i can see notifications from iMessage.
--- [ personal ] --> Photo modes, i would useHasselblad Hi-res for most shots, Xpan when im dealing with small pair of people or scenery
and portrait for everything with a face or a define subject in focus. or even food.
Still on the 2nd week , still going strong with the amazing features of this phone.
For the rest, do appreciate to chime in and quote me, so that the mod can recompile something on the first page later on for the next batch of late comers,
which i bet is still being sold .
I
image to text
iirs build in camers app
open oppo camera app and scroll to more then select text scanner
chari-men
hear say 1tb will get the 400+200mm kit together, and kit wont be sold solo when release
the kit they will release on a later date to sell ala carte lo.. seems like come here with coupons shud be able to get 1.3-1.5k liddat.. quite decent ba..
NeonX
Jokes aside,
- all oppo find n6 comes with inner and outer screen protector, is good , just dont remove until 2 months later when theres more tested and reviewed batches or even @tkte_85 mentioned place.
Circle to search no need install, just hold the bar at the bottom.
Battery wise you mean smart charging?
BradenHeat
yea, i see a few who did the oppo app transfer instead of the qr code. or maybe its specific for samsungs ?
from vivo to this oppo zero problems ...
masashi
Some pics of the 2 leather case just arrived. Think I prefer the orange one more since it has a ring behind as a stand:s34:
Edit: Added more pics for the brown leather case since it's underrepresented here
BradenHeat
dang, thats looking solid,
at least the hinge got coverage
the ring / stand isnt gonna cut it if you bring it into the showerroom
have the stand or better from challenger is my recommendation.
OnePunch!!
I feel if u wanna scan text/ image text
just use the oppo camera text scanner or Google lens
ya one ui Samsung camera is more all in one
no need to think twice which app to use on a oppo
like I like one ui one handed app and their good lock all the add on hacks Damm power customized
masashi
stand isn't bad. For the price of oppo official case, I got 2 solid leather case instead
BradenHeat
Becareful but try opening it up unfolded and you will know what i mean. lol
i had that stand for a reason, because vivo x200U is heavy..... the ring type when hooking on to the wall hooks, will self rotate into an odd and awkward angle
NeonX
Btw anyone manage to find non full coverage screen protector that's AR and can use front case?
Yuripa
Can I check where to find oppo camera text scanner?
