Oppo Find N6
TanKianW
Felt the original Oppo casing was too boring and did not come with the MagSafe I needed. Changed to another front and back Aramid case which protects the sides and at the same time supports MagSafe.​
Computeron
Hi bro, can share the clear case you bought
those normal ones... nothing special.. can find in. tb... I think all seller selling same.
mine less than s$5 nia.
most of the cases u all bought.. I used before in my previous v3 n zf7 liao... bit bored.
stupidog
stupidog
looks pitaka.....
Apparatus
2 days ?
need tri-fold?
max volume is low ?
camera is unfortunately a trade off else it will be 2.6k
volume wise, have you even tried the echo app ?
What's this echo app? Need to download from playstore or default in N6?
Apparatus
Can test whether the MagSafe is strong? Thanks
Vulpix
Moderator
Moderator
Guys I read on Chinese social media some dude accidentally trapped sand between his screens end up scratched the protector like crazy. Maybe just be aware when you go to the beach. Sand is no joke.
Yuripa
Or dusty places
Once you hear crispy cracking sound when you open the fold
That's when you know got UFO enter into ur phone liao 😲
Legend: UFO = Unidentified Fine Objects 👽
chari-men
Due to this no crease tech design the gap is a water droplet shape kind.. so very easy to get dust trapped inside..
chari-men
Or dusty places
I think enter screen still ok at least can clean.. if enter hinge then a bit mafan ...
BotakGirl
ya until i givem up on Samsung ultra
its not thr 10bit hoohaa issue its the pixeliated display i aviod it all cost
SuperDecker
Vulpix
Moderator
Moderator
I also want to caution everyone that our phone using silicon carbon battery, so don't expose it to high temperatures. Like don't leave it in the sun, play genshin in the middle of the Sahara desert. Normal charging heat should not do anything to the battery. Playing games should be fine.
Right now many companies still avoid this battery because it's still not proven to be reliable in consumer electronics. Sure thanks to this tech we can squeeze in massive batteries into smaller phones, but at what cost? No one really knows outside of lab tests.
