Thirsty Hippo?
NintendoSwitch
Where do you put these disposable dehumidifiers in aircon rooms? Near the door? Under the aircon? On top of the shelf?
iu
SimpleToo
Normally put in enclosed shelves?
if put outside it will absorb alot moisture very quickly and will require a replacement… especially in sg weather
On side note, aircon is considered a dehumidifier as well… (esp if u use the dry mode)
ceestudent
This is for cupboards and small space, not for whole room dehumidifier.
To dehumidify the whole room, you need bigger dehumidifier that is plug to electricity. The elecricity usage pretty high though, like 100-200watt one.
Apparatus
I put inside a cabinet which contains my 4K Blu ray discs
When some water appear I changed them
fade_white
Put outside the house lah, it’s super effective the next day u see it suck moisture until reach max level.
chaiscool
100-200watt is not high lah, on 24/7 also likely use as much as water heater tank.
Krabs.
the main point is import the industrial chemical in bulk then separate into little package at higher unit price :o last time shopee had a streamer every day put on thick makeup to sell this topup refill
futile effort .... it doesn't work .... it's like trying to keep yourself dry in the rain with a paper umbrella that melts away :o the whole business is make you addicted to keep buying it repeatedly thinking you are solving a problem but is a salmon swimming up a river
