I have a particular unit of Seasonic M12ii 620w that was kept in storage for a long time that was hardly used, no dust at all, still can pass off as new.
This model existed during Z77 times, and I just tested it on a Z77 setup (i7 3770k, R9 Nano and a stick of DDR3 RAM) and it boots to BIOS.
I have a Z590 setup with an i7 11th gen and an RTX 3060 that needs a PSU, and I’m thinking,
well … I got a PSU right here …
Is this an
“It’s fine, go ahead” … or a
“Don’t do it man!” for y’all?
I strongly advise you to change your PSU as over the years, the resistors or even caps will degrade.. with modern tech that are heavily drawing current. it's unsafe to run an old PSU on mordern componets.
Well...their warranty is disappointing. Most PSU at their price point offers 7 - 10 years warranty. They only offer 5.
Having PSU warranty locally is all good. I have my take about PSU with a 10 or 12 years warranty though.
The Good
- if within the 3 years period, you might get a replacement (1:1 Exchange) or send it back to AIB for repairs. most cases, if local distro have the unit, they will just do 1:1 Exchange.
The Bad
- After a certain period of time.. 5 to 6 years maybe. Yes warranty does cover but you might not get back the same model as it may discontinued and either you get an upgrade for free or top up for a better model. For topping up to a newer model, the warranty period follows your old PSU and not the newly top up PSU.
Afterall in general, I will treat all pc parts able to sustain 5 years and then overhaul after, even if PSU have a 10 years warranty. All electronic products will degrade.
As for choosing of PSU, alot will recommend
https://cultists.network/140/psu-tier-list/ but personally I prefer to look at
https://www.cybenetics.com/ . I don't really care about brands but more of the OEM. the grade as in platinium current drawn, ripple signature, spikes and etc.
1st Choice OEM FSP, CWT, Great Wall, Seasonic (To be honest, I am more towards FSP more than seasonic, for budget PSU that is)
2nd Choice OEM Zhong Yuan Power, Shenzhen Xinweiye Technology Co (these are budget but some AIB uses these for there mid tier PSU, Lian Li, Montech, First player and etc)
These PSU which are always on my list.
Mid Tier PSU
1)
Seasonic Vertex PX1200 (My main rig using)
2)
Montech Titan PLA White 1000W (My capture rig)
3)
CPS PCCooler YS1000 1000W (My Open Bench)
Budget PSU
4)
Montech Century II 1050W (often use for friends or collegue's build)
5)
FSP VITA GM 1000W (often OOS so to use 4) which is reliable too)
6)
Lian Li SX1000P (is not a bad PSU but mainly for friends who wants Lian Li ego system.. full on Lian Li, btw these psu is far more better than the Lian Li Edge)
