Can recommemd simple stove , induction cooker?
Lchlch
Turn the knob, no sparkling, changed battery, still no sparkling but can hear the gas coming out..
Lchlch
I thought of getting simple induction cooker, but my existing stove need to remove, got a hole if eemove, how?
Can Or Not
Induction cooker got power rating… need to get one enough power…
106gunner
Is all the burners fire wouldn’t turn on or only one burner?
Using a gas lighter will do the trick to turn on the fire
keenklee
Stove better or induction Vos if induction, my stove area got one hole..
IMHO.
Change to a similar stove to cover the hole.
Buy a single induction hob - use electricity.
Induction is 35% cheaper to boil water.
Or, just find a suitable induction hob and ask someone to replace the stove - power requirement could be an issue.
106gunner
I have same issue on one of the burner previously
Is not spoilt, can hear the gas sound upon pressing the knob
Probably oil and food stuff could have cause the burner not to ignite upon the knob press
A gas lighter will solved the issue
Lchlch
IMHO.
Thks if that can save money.
I am using cylinder gas tank.
virtualape
just get those igniter gun...
can hear gas sound means its working...just the built in igniter is faulty.
