Hi all, can you check if your OLED screen (laptop or monitor, including QD-OLEDs) is able to show the first 5 levels above black properly at standard 100cd brightness? All my LCDs can (I stare long enough to let my eye accustom to darkness), but not a single OLED screen I have can, even Ipad Pro 13" with Tandem OLED, no matter how bright I increase the screen.
Use this: http://www.lagom.nl/lcd-test/black.php
or this:
Note: some OLEDs are non-uniform, i.e. peripheral of the screen may be brighter or darker than the center causing the sequence of brightness of the squares to vary across the screen.
Because I thought this problem of black crush was been solved for OLED.
It looks like generally any level 5 and below is not possible for OLED? Or is it just really too dark to be discernable by eye?
This has implications for OLED M6 Macbook (Samsung Tandem OLEDs). I was thinking of postponing purchase of Macbook to OLED M6, until I realise my existing OLED Windows laptop screens seem to have also have crushed blacks that deceived me into thinking it has better blacks.
or this:
