Google Pixel 11 series
chari-men
bought a 200 bucks used pixel 10a off carousell.. let's see if the performance difference is significant compared to the 11 pro..
Loser
You're really committed to destroying the reputation of testing pixel devices. :o
That's next level commitment bro wait for your review.
chari-men
saw a good deal so took it lo.. coz tbh for the things i do on pixel 11 pro.. i believe 10a also can achieve the same..with less ram and no telephoto.. let's see if pixel 10a is sufficient for day to day normal use lol..
Loser
So you bought it with the intention to use it as your daily driver if it suffice your use case?
chari-men
alr removed all the games and 4k movies coz it doesnt work well in the pixel 11 pro lol.. if 10a doesnt lag i can consider triple wielding with my vivo x200 ultra + huawei mate XT trifold...
Loser
Why 4k movies don't work well?
Y'all really next level. :s14:
chari-men
Yes. It's worse than before update for me. Just now can't even pay for lunch due to network issue. This is like the 10th or 11th time since morning.
seems like got some 5G bugs + etc listed by google gemini... maybe try switching to 4G first???
The September 2026 update (accompanying the September Android Drop and security patch level CD1A.260905.001) has just begun rolling out across Pixel devices. Early adopters and community reports highlight several notable bugs and regressions:
Known Bugs & System Issues
  • Spontaneous Screen Wake-ups ("Ghost Waking"): A widespread sensor calibration bug causes screens to wake up repeatedly on desks or flat surfaces without physical contact.
    • Workaround: Temporarily disable Settings > Display > Lock screen > Lift to check phone.
  • Video Boost Static Audio Glitch: Pixel users recording with Video Boost enabled are reporting noticeable audio bursts and static clicking every few seconds in the rendered file. Google has confirmed a fix will arrive via an upcoming Camera app update.
  • Intermittent 5G & Wi-Fi Handshake Drops: Some users are seeing sudden network drops after the phone sits idle, with devices refusing to auto-reconnect to saved Wi-Fi networks or getting stuck displaying 5G with no actual throughput. Toggling Airplane Mode or resetting network settings provides temporary relief.
  • App Crashes & Installation Hangs: A subset of users report that Play Store app updates hang in a "Pending" state post-OTA, requiring a cache wipe of Google Play Services to complete.
  • Motion Assist Calibration Stutter: The newly introduced Motion Assist feature (designed to reduce car-ride motion sickness via screen overlays) has caused micro-stutter in third-party launchers when enabled.
If you rely on your phone for critical daily workflows or video recording, pausing the update for a few days while carrier-specific patches and Camera app hotfixes roll out is recommended.
Loser
  • Spontaneous Screen Wake-ups ("Ghost Waking"):A widespread sensor calibration bug causes screens to wake up repeatedly on desks or flat surfaces without physical contact.
Heng I never pay extra for early updates :o
I always get updates later than others one. :frown:
kEvinErd
Maybe you should test Pixel 9a instead because 10a is basically 9aa. Hahaha 🤣
manofsorrows
scanned the QR code for the Spigen screen protector. its finicky. I turned off the toggle and the fingerprint unlock works better.
rinchan22
Yeah. If 5g will randomly disconnect and sometimes stay connected but will have the "!" Mark on the reception bar icon. Sometimes it's greyed out and auto switch to 4g after. Hopefully will be fixed soon else I'll probably switch to 18pro max in 2 weeks.
Loser
Switch switch switch. :s12:
Damn embarrassing and people keep saying their software is up there. :spin:
Now I don't dare update my phone. :frown:
chari-men
tried uploading a 30gb file to gdrive and the app just hanged and crashed after 15 mins.. bravo lol..
rinchan22
Probably best to wait a few days before updating. Let others report any potential issue first.
This issue really made the phone almost unusable for daily driver. Had to ask my colleague to pay for my lunch first then I pay back later. So embarrassing.
Loser
No excuses for these kind of thing. Basic function also can break on a public rollout.
Their internal cutting edge Gemini model never help them double check their code before release?
I want to join @KeYoKe and @chari-men and form triple-threat team liao.:s15:
chari-men
just being honest in my feedback lol..gave up on gdrive.. just copy to my external ssd gaodim in a few mins..
