If want to buy PC for office work Intel or AMD?
Gaming AMD or Intel processor?
AMD and Intel which one processor faster?
Like see YouTube open file
AMD have the fastest CPU that works the best for gaming.... as they have the X3D models which featured a lot more L3 cache which improves gaming performance... but it dose not mean you cannot use it for office work just that it is wasted if you only use it for office work..... and for those professional software you actually have to rely more on the GPU....If want to buy PC for office work Intel or AMD?
I think Intel is chosen because of the super cheap Celeron is it...Not really, it depends on the price.
Usually for office people go for Intel.
AMD prebuild PC for office there are not many out there cuz
most are for gaming.
I think Intel is chosen because of the super cheap Celeron is it...![]()
I find that corporate PCs tend to be Intel. Not that AMD is bad of course.
Eg. My Lenovo Thinkstation P330 1L and HP Elitedesk 800 minis have been running rock solid 24/7 for more than a year now.
You have a lot more stuff to play around with in the BIOS for AMD so I think it suits gaming enthusiasts more.
Might as well buy NUC.At the higher end CPU for Intel or AMD... it is the same lar...you dun really touch the BIOS other than to set XMP for Intel RAM or EXPO / DOCP for AMD RAM settings.. it is mainly to set the RAM to run at the higher speed it is rated to run at, any other settings like overclocking is a bit of waste time nowadays.I find that corporate PCs tend to be Intel. Not that AMD is bad of course.
Now still have Celeron?
This one super lag sia
if AMD chip is faster, i expect my staff to work faster on an AMD computerAMD and Intel which one processor faster?
Of course. You can install the same Windows OS or any operating systems you choose.AMD can run office software all these?
I don't disagree.At the higher end CPU for Intel or AMD... it is the same lar...you dun really touch the BIOS other than to set XMP for Intel RAM or EXPO / DOCP for AMD RAM settings.. it is mainly to set the RAM to run at the higher speed it is rated to run at, any other settings like overclocking is a bit of waste time nowadays.
So far my default EXPO setting by the RAM is working fine... only setting I do is to change something that will make it more responsive... but too long never touch also forget simi RAM setting already.I don't disagree.
I run RAM at JDEC profile but still sometimes will encounter Machine Check Exceptions (MCE) and uncorrected / software containable errors for Proxmox. AMD CPUs just don't play nice because of their aggressive c-states or like you said PBO settings. Takes more effort to tune otherwise you will get unexplained crashes and unplanned shutdowns
