- Aug 8, 2012
Jialat la, you poisoning me...
@|XcElLeNcE|
@|XcElLeNcE|
@|XcElLeNcE|BBBMTL…you have two months of “trial” should you decide to return or keep it. My last iPad experience was before M1 on iPad Pro.Jialat la, you poisoning me...@|XcElLeNcE|
with the extended return policy, now can hoot first talk later. @|XcElLeNcE|
use for 2 months, not happy return in january
For real, if I am on Mini 6, confirm whack. On one hand, the logical me is refusing while on the other is - BBBBBBBBBMTLBBBMTL…you have two months of “trial” should you decide to return or keep it. My last iPad experience was before M1 on iPad Pro.
BROOOOOO, don't start this again here with the Mini too please!Those whom have received the iPad Mini, can help back what OLED panel they’re using? Which Samsung panel? G9x series?
Yes, today started liao, 06NOV2026 - 25DEC2026, returns on 08JAN2027When is extended holiday returns starting this year? Is today?
https://9to5mac.com/2026/06/23/appl...l-reportedly-rely-entirely-on-samsung-and-lg/BROOOOOO, don't start this again here with the Mini too please!![]()
This one need @|XcElLeNcE| to confirm liao.https://9to5mac.com/2026/06/23/appl...l-reportedly-rely-entirely-on-samsung-and-lg/
ET News says Samsung Display will be the sole OLED supplier for the iPad mini, foldable iPhone, and MacBook Pro, with estimated orders of 2 million, 10 million, and an unspecified number of panels, respectively.
Based on news reports, and per check with google gemini, they said is samsung oled
Back then my first and second gen iPad Pro was only used to play games which is already overkill so don’t see the need for M series chip. After using the Duo kinda sway me to buy an iPad.For real, if I am on Mini 6, confirm whack. On one hand, the logical me is refusing while on the other is - BBBBBBBBBMTL![]()
Wowz, that is really long ago if its before M series chips![]()
But you got Duo still need iPad Mini? Doesn't both devices functionality & capbailities overlap?Back then my first and second gen iPad Pro was only used to play games which is already overkill so don’t see the need for M series chip. After using the Duo kinda sway me to buy an iPad.
I returned the Duo for 18PM and Mini pairing. Apart from being no longer as portable or foldable, I no longer need to worry about inner screen durability or weaker camera.But you got Duo still need iPad Mini? Doesn't both devices functionality & capbailities overlap?
Oled vs lcd… no fight at all.Went to try iPad mini 8 and compare side by side with my mini 7. The display on mini 8 blow the mini 7 out of the water man!
Display so much sharper because of the OLED!
got mine today and using now. No promotion 120hz what a shame, noticeably less smooth vs my 11 and 13 inch m4 oled ipad pros. Overall size and weight is good.
It’s a G9L panel.This one need @|XcElLeNcE| to confirm liao.![]()
Paging @kashixIt’s a G9L panel.
