iRobot Scooba experience
seowbin
Just an update, I got my package from Irobot yesterday at 5:15pm
opening the box
my purchase. From left to right, roomba570, scooba380 and roomba400.
btw, buy individual transformer or use a multi plug to charge my mini army of irobots?.. :D
get a huge step down convertor... (or is it step up? lol)
from 240v input to 110/120v output
den use ur multiplug
check ur multi-plug adapter 1st.. should be no problem support 110v/120v voltage.... i bring one bar to US during my attachment before to charge my stuff
dankoo
such a big box, how much is the comgateway charges? :s22:
For me, I would get individual transformers as i am not charing them for 24/7. So after 3hrs, i need to off it. But of course, I got timer plug to help me to auto-off it.
Ya...pls share how much is the shipping charges?
sunsetbay
Moderator
Moderator
what's the total damage?! :s31:
silversurfer
Total shipping charges is USD$100.50. total weight is 29kg (volumeteric weight).
hmm, thought i read from somewhere in the instruction booklet to keep the battery charged all the time? :s11:
mosmos
High Honorary Member
:o yah, many had mentioned they charge it 24/7 to get best results.
sAxman_Returns
not considered charged 24/7 bah, i think it's to maintain its current only is it? But I think it is not taking a lot of current lar, compared to using normal vacuum cleaner running at 2000W....
Any idea how much would it take for the battery to run out? the 500sqft one....
mosmos
:s11:
change 2 times water will battery run out. :o
sAxman_Returns
huh? like that one? how much area can single water tank cover? i thought it can 1 short clean up as much as 850sqft....
chewpc
Does the shipping cost your mentioned includes GST?
sAxman_Returns
GST is payable @ Singapore. As long as your total cost, including shipping charges exceeds SGD$400, GST is payable. That's why sometimes is not wise to combine shipping. 7% is a lot of $$$$...
mosmos
:s22: no lah, water will still run out and you will have to refill.
eg 850sq ft, covers abt 425sq ft water will finish.
mosmos
:s22: yah, sometimes separate shipment is cheaper.
molecule
A storage tip for all reman scooba users. After running scooba u probably need to air dry your unit. I got this large coaster from IKEA for less than $3. Fits just nicely and works great for me to keep it off the floor, better than spending $$ on the original iRobot storage mat. :yawn:
Original iRobot Storage Mat US$12.99 here
sAxman_Returns
molecule, your scooba dun come with a storage mat?
have you tried the scooba on your parquet/laminate floor?
sAxman_Returns
:o can mop larger area mah.
how to mop larger area when 1 tank can only handle <500sqft? you get what I meant?
you can just leave it there and run, you still have to clear the tank when it's full and it's not able to cover 850sqft in 1 tank what?
mosmos
:s22: eventhough a battery charge can cover larger area, the water tank is still the same size.
380 move faster and spray less water, so it can cover a larger area per water tank.
The battery 380 has is only able to run 2 tanks of water.
Other scooba also has same properties, you need to change water after they had used up.
