SET ST536v6 to bridge mode
Diavonex
Try method 2
1. Connect ST536v6 to router's WAN port
2. Connect computer to router's LAN port
3. Set PPPoE (username and password) on router
4. Hard reset the ST536v6 for 10 to 12 seconds (use paper clip to poke hole behind ST536v6)
5. Surf the internet
Note: I you still can't connect, hard reset the ST536v6 a few more times.
Dellboy
Hi Diavonex
Some discussion back you mentioned that double-routing not a good method of connection. I have done this before and it worked well.
One more point, why do you propose for router to perform DHCP instead of the ST536? In another method that I have done, I switched off the DHCP in my Linksys router, connect the ST536 to a LAN port of the Linksys and have ST536 do the routing and dialing. Isn't this easier than to convert ST536 to bridge mode?
Please advise.
liangtam
There is no right or wrong as to which method you choose actually.
pleeted
in what circumstances we need to set bridge mode? Only st536v6?
OR
Any ADSL Modem Only + A Wireless Broadband Router?
Eg. does the below need to set bridge mode or just can use straight away if the two devices are link together?
speedtouch modem + wrt54g
2wiremodem/mio + wrt54g
liangtam
All the 3 examples above, u nid to bridge it. If not, working in double routing mode is also possible.
Half-bridge mode oso possible if the modem supports it.
pleeted
thanks for replying, it seems kinda a troublesome to set in bridge mode, also, this thread is dedicated to this specfic model and the tutorial seems quite complex.
May I know how do I set bridge mode for modem like 2wire in bridge mode?
What you mean by double routing, does it need configuration also?
Dellboy
Pleeted, if you have the time, try this out...
Let the 2wire continue to perform the dialing and routing function (DHCP enabled) and turn your WRT54G into a switch (turn off DHCP). Connect 2wire (Ethernet out) to one of the LAN ports (not the Internet port) behind the WRT54G.
This method, don't need to flash anything.
MJL111
:s11:I have this ST536v6, and the Linksys router BEFSR41, which I am unable to connect. I have tried downloading the .iso file, but my username/password are not being accepted. :s22: I have been trying to get this set up for a few days now, and am getting quite frustrated. I am not very computer savvy to begin with, so please help me???
pleeted
thanks, so it will confirm work for 2wire modem? how about a speedtouch modem, can it work this way too?
Darwin09
Help Please.
Diavonex, I've tried your residential cd to bridge my ST536 (6.2.17.5), but still doesn't make it to work with my linksys WRT54G router, still not having internet connection. Pls do send me Screenshots to guide me. My email: dfmarcelino@yahoo.com I'll post my feedback afterwards. Thank you.
zizourox
Hi guys. need help setting up speedstream 5100 with linksys wrt54g. Do i need to set the modem to bridge mode? TIA.
Dellboy
Pleeted, should proceed with speedtouch as prescribed. Do report back and share.
zizourox, do follow what I have prescribed in #371. Don't need to set to bridge mode but simply input your dial settings in 5100. Next, turn off DHCP in wrt54g. Connect LAN cable from 5100 to one of the LAN ports in wrt54g (not the Internet port). Try this out and report back.
liangtam
Wrong thread.
But yes.
Poke the unit to bridge it, like some of the ST536
liangtam
SS4100/5100 got a serious bug. Bridge it better.
zizourox
Dellboy, doesnt work. Still unable to get to internet for both comps.
liangtam, sorry i posted in wrong thread. But i cannot find the 5100 configuration page. Any idea what it is? Or is there any in the first place?
Dellboy
zizourox, try 192.168.0.1 for the configuration menu and google around for bridge mode configurations.
liangtam
Setting it is not inside the modem web ui. See my 2nd post back on how to bridge it.
cheapsupps
Try method 2
hi can u send the screenshot to my email ngkahleong23@yahoo.com? Thanks.
AttentioN
Try method 2
This is the most direct method, that worked for me since day 1.:)
but i dont have to hard reset that much - at most twice.
crone~
hi guys
i've tried the method and it worked. i'm connecting the router wireless to 2 laptops. however, i'm unable to connect both at the same time. anybody can help me with this? the 2nd laptop to connect will get a error msg saying there's conflicting ip address. thanks for the help guys. a computer noob here.
