Official Carrier Settings for both STARHUB & M1 (Cellular Data Network Accessible)
kelvinti
Can I have Singapore Airlines tail logo on Starhub 5.1 please!
I want my SQ gf to have it, can?
Thanks in adavnce! Hehe :p
JeNoVa-IcHiGo
Done, Check please. Inform me if there's any issues.
Link :
mediafire.com/download.php?odlzxrfdizu
Airbrush
hm...it should work...off ur itunes, run test.cmd then try restarting your computer...then try again...make sure u are in an administrator acc on the computer
Bro....
I restarted my comp... did everything as per instructed... still cannot get the carrier-testing to work leh...
*frustrated*
edwinrz
Hey Bro, I don't understand why I couldn't find the iPhone folder to locate the ipcc file.
I have already typed the command in cmd.
Using SingTel set with StarHub SIM.
Any idea anyone?
JeNoVa-IcHiGo
Bro....
*frustrated*
hmm...where is ur itunes installed? issit the normal c:\program files\ ??? if its not, try changing the command appropriately.
JeNoVa-IcHiGo
Any idea anyone?
what u mean locating the ipcc? its in the mediafire link i gave~ hahah...a for carrier testing portion, read what i told airbrush...might apply to u too.
cheers !^^
edwinrz
yea i did all those, but i cant locate the folder where u keep ipcc files. :/
edwinrz
i mean inside my C drive directory.
located in some iPhone folder right? i cant find that..
AnDyLe0
btw... if we use this custom ipcc file... can reset back to official one anytime?
thro network reset? or must manually transfer again?
edwinrz
basically i can't get to this step..
There's no program files > iPhone > ipcc in any drive of mine.
Sorry abt this. Really thanks alot!
I try email u too
Sullen
so by using this, i can be in a call and surf the internet at the same time?
Cause currently the phone doesn't allow that.
JeNoVa-IcHiGo
You still can't do so. For iPhone , seems either call/data connection can occur at any 1 time even thou 3G is supposed to be able to support both together.
AnDyLe0
Hmm...If u wan i can upload the official one as well. Just reply to me :)
nvm. i haven't customized yet. ask only in case next time i wan to customize it.
that means after overwrite the official one, cannot revert back.
and i saw in the link of another thread that provide the logo...
it stated "do not change APN else need to repeat all the steps again"
does that mean even with the settings page still cannot change?
