Air conditioning - Any recommendations please??
buibuisnail
any idea of workmanship of
Hong Huat Electrical?? someone found my same specs but $220 cheaper.
I'm more conerned with e workmanship & reputation then e price but still
anyone tried out their services before???
terumo
Change whole system plus piping will be better.
Hi, need some advice here after reading through many of the posts here.
I want to change the aircon in the 3 bedrooms as they are already 9 years old and start having problems. Currently using Daikin 4MK75FVEN (inverter with R22). The piping are running in the false ceiling. Bedroom sizes about 120, 130 and 150 sqft.
Thinking of changing to non-inverter aircon like Daikin MA56EV1 but worry not cold enough. The other alternative is to go for inverter aircon but cost about $1k more. Usually we will turn on aircon in 2 bedrooms throughout the night. Any advice?
Should I change the current piping? (I know if I change to R410a gas, then must change piping). If don't change, worry got problem later. If change, it will be messy and not sure if the shop can patch up nicely after installation. Anyone has experience on this?
Do the shop normally charge for removing existing aircon?
Thanks.
gerome801
Buying System 3 Inverter Aircon - Any recommendation?
Hi everyone just joined and this my first posting. Jest got the keys to my new HDB 4rm flat and want to instal System 3 inverter aircon. What brand is reliable and reasonable priced? Any good installer to recommend? Hope someone can advise me - thanks!
jimmy_07
Just to ask some opinion as looking to install air condition. My masterroom is around 30sm and common room is around 15sm.
From the website calculator, it seems I need around 12k BTU for Masteroom and around 8k BTU for common room.Initital I am eyeing for mitsubishi starmex but seems it is running out of stock now. GC guy introduce me toshiba
However I am having doubt on the combination:
1) RAS-4M26SACV( system 4 outdoor unit with 34k BTU), RAS-M10SKCV(9000 BTU) X2, RAS-M16SKCVX1
2) RAS-3M20SACV( system 3 outdoor unit with 24k BTU), RAS-M10SKCV(9000 BTU) X2, RAS-M16SKCVX1.
First doubt : Can RAS-3M20SACV support the second combination without any problem if I always on 3 aircond for night?
Second doubt :Is RAS-M16SKCVX1 enough for 30sm room or I need RAS-M22SKCVX1 for masterroom ?Actually the GC guy recommend me RAS-M22SKCVX1 before I get the web calculator.
Appreciate help from all expert here. Thanks
chunxi
wah, i ask the gain city people, they say mit ele will only have stock march or april.
wyx03_2002
GC CCK told the same thing, ME no stock, earliest March. Is ME no stock islandwide or juz GC? Can all specify which GC u visited? If all at CCK GC, then we can bulk purchase and ask more discount =:p
BTW, I m still undecided whether to get ME or Toshiba... expect to on aircon in MBR for 6-8hrs daily. Pls advise:o
setup 1: RAS-3M20SACV (outdoor, 24K), RAS-M13SKCV x2
setup 2: MXY-3A28VA (outdoor, 30K), MSXY-GD18VA, MSXY-GA13VA
chunxi
does it apply to inverter or non-inverter aircons?:s11:
not sure.
they got paste a formal letter from mit ele saying no stock, blah blah blah....
the gain city say as there is only 1 distributor for mit ele, so whole singapore also not stock.
lwm999
30sqm is a big room! Normal MBR maybe around 12-15 sqm. You probably need 18,000BTU or more for it.
Say if your numbers are correct (12k, 8k), if you on 3 rooms at the same time, you will need at least a 28k BTU system. If does not mean if the FCU is rated 9k BTU you will get 9k BTU. For your second option, you are only gettting 5,400BTU and 9k BTU when all 3 rooms are on at the same time. Even the first option is not able to meet your requirement whether you are using M16 or M22 FCU.
tnk001
I just want to share my bad experience with Best Tech in IMM. I ordered a ME Sys 4 from them on 20/12/09 and paid a deposit of 700+. The installation was supposed to be on 2 Jan and the guy promised me the workers will come in the morning as it will take quite long.
A few days before that, the guy called and tell me that there are no stocks for the aircon I want. He said that new stocks will only be available later and we agreed to move the installation to 16 Jan.
On 15 Jan, they called me to confirm installation on 16 Jan ard noon time. I was a little puzzled as based on their sales guy when I signed, the project cannot be completed in half a day. But the guy on the phone was confident and said at most they work till late in the night. Although I wasn't very happy, I said ok.
Then on 16 Jan, my family and I moved everything away early in the morning to facilitate the installation. Then we waited till around 1pm and nobody turned up. We finally called the office and the lady said the workers cannot make it. Also, she said dun call back after 1 as nobody is in office.
She then offered me to re-arrange another installation date. After some discussion with my family, I decided not to proceed as I have lost confidence in the company. I am now in discussion with Best Tech to get my money back.
It has just been a very bad experience with them. Now, I will probably have to wait till after CNY to look for another company again. When I signed with them, they promised me the stars and the moon and all I got was this kind of rubbish.
tinydot
omg this is bad...mths ago i ordered panasonic non-inverter a/c from gain city. good service from the sales and the installation pple. after installation, i thought the a/c wasn't installed properly as it was not cold(posted here for this problem b4 in this thread, u can do a search), give a call back to the sales guy, he arranged for the workers to come down to take a look the soonest possible FOC. but the prob was me lah, installation was ok..heh
edit: i ordered on a sunday, they came down on thurs to fix. i guess a/c popularity plays a part. panasonic is a decent brand(i'm happy so far), but perhaps not as popular as starmex or ME.
cueball1981
Wow... honestly if i remember no wrong my Ac is also from them.. same problem arise.. say what AC fell on main con foot and AC is dmg.. and no stock.. Waste me one day of leave.. then i dulan.. i check with i tink renotalk and it seem this thing happen before .. so i told the lady on the line that i make the whole issue big if i dont get it install in the same week.. Next i know.. they got it install..
jimmy_07
Thanks for your reply. However the only biggest BTU for tohisba outdoor unit is only 34K BTU which is RAS-4M26SACV.
Is it mean if I want to go for this brand will be( check with toshiba catalog details)
1) RAS-4M26SACV( system 4 outdoor unit with 34k BTU), RAS-M16SKCVX1, RAS-M10SKCV(9000 BTU) X2 with 3.4,2.05,2.05 Unit capacity (11.6k & 7k BTU)
2) RAS-4M26SACV( system 4 outdoor unit with 34k BTU), RAS-M22SKCVX1, RAS-M10SKCV(9000 BTU) X2 with 3.94, 1.78,1.78(13.4K BTU & 6k BTU)
Does this mean both setup will not cold also? Should I separate the MBR aircond from the system 3 and install as individual unit?this will cause my air condition totally out of budget if I need 2 compressor now - -
buzzmario
are they going to pay the 700 back to you? if not, might as well get them to install but need to monitor closely during the installation. to forgo 700 to get new company it too great!
tnk001
I've talked to the sales exec who served me. I think it should be ok. Definitely will not forgo 700 dollars lol.
I guess I will probably go back to GC and bear with the increased cost. Better be safe than sorry.
chunlianghere
Hope everything goes well on the installation!
Btw I feel quite sad tat since tv advertise starmex, n they now dont hav stock lo.. But well,going for other brand is gd. Doesnt mean tv advertise one is gd. It can be bad too. Cheers!
cannotliao
actually what the cause of problem? :s11:
thank
lwm999
Why don't you call a shop like Gain City to go to your place for a site visit, to advise and propose you some models? They can also check on the room sizes to find the right fit.
Just to check that you only measure the length and width of the rooms to get the room sizes, and did not mulitply the height, right?
tellim
although process is not smooth but it just some hiccup on the installation date. i think if u request for ur deposit back, u gonna bring more headache for yrself haha.
i gotten my aircon from best tech and no hiccup encountered. aircon is still working fine few mths after installation.
