Show off your Springboard !
Sonic76
yuppers very complete theme wif lotsa splashscreens :)
Hi bro
Just to find out from you, when at the lockscreen i am able to see the 3G icon but once i am at the homescreen the 3G is not showing.
Do you have the same problem as well?
hyperpower
guys I tried to use a 640 x 970 px wallpaper on suave HD theme but the wallpaper did not resize properly. need to scale down?
Cryptrus
My latest springboard :)
Can i check how you guys get the weather onto the spring board? i installed WAD widget and the lockscreen is showing the calendar but the springboard no weather at all even after i switch it on in winterboard.
lao3hero
Hmm.. Can u try another weather widget and see if it works?
hossann
My new Lock Screen and Answer Screen
No need to slide to unlock and answer call so troublesome just tap once to unlock and answer call can liao :D :D :D :D :D
New Lock Screen
Answer Call Screen
Very nice background pic. Where can i donload the lockscreen app and the answer screen? how to get the pic to be the background pic?
whatme
Is there no way to set the wallpaper itself in the phone unless i have to change in their own file?
Can anyone tell me how to change the resolution? i try putting the wallpaper but its too big, somemore when i try to resize, it gets uglier
