I notice that some shops tend to apply it before pasting a SP on it. Does it help?![]()
You tried it before? It doesn't harm the screen in any way? ThanksA good solvent that leaves no residue.
Unless u r a pro, else use mircofiber will be enough.
This message is sent from HWZ forums iPhone app
Any solvent applied will damage the oleophobic screen. Be wary if you see people put too much alcohol/window cleaner/zippo fluid/etc...
Not sure about Zippo fluid but alcohol does strip away the oleophobic coating on the screen.
How to tell if it’s stripped off? Those wipes that usually come with screen protectors![]()
