Where to buy Fibre Optic Cable for ONT terminal
cqprime
I managed to buy a pair of fibre optic cables for 50 dollars (1 pair is 25 sgd) Yellow color
from UF Technology Sim Lim Square #03-69
anyone knows anywhere cheaper ?
Qubicfactor
UF technology is wrong type one
They do not have the APC polish kind (green connector).
cqprime
I just got back from SLS and seems like all the shops i went around sold the same type i bought earlier.
cqprime
Photo of the cable : Duplex mode
[/IMG]
Anyone got pictures of how does the cable look like?
whaleshark87
Oh this kind, only singtel counterparts would be able to find.
I only have the Duplex type.
cqprime
The one i showing is what i bought from SLS....all SLS selling the same type of cable. The one M1 gave me is green color connector.
BlackIcE84
from what i udnerstand:
Connectors: SC on both ends
Polish: APC on both ends
Mode: Singlemode
duplex/simplex: Simplex
does any shop sell this?
Qubicfactor
http://www.huihongfiber.com/fiber-optic-patch-cord.html
I see a whole list of them here. ALl with different ends. SEems that the LC Fibre patch one is more correct eh..
LC isnt correct. It is SC type leh
TS one is nearly correct, but the blue connector indicates it is not APC polish
Should be green, like the following
http://cgi.ebay.com.sg/SC-SC-FIBER-...558?pt=LH_DefaultDomain_0&hash=item56371745e6
In case you are wondering why should be APC polish - I still have the box for the Opennet TP, and it clearly states APC type. Fibre cable from Singtel also has a green connector.
Only thing I am not sure about is if 9/125 is ok, since the Singtel cable is 10/125 and some say all single mode can be regarded as the same, but others say using a smaller diameter cable will cause some signal loss.
Got this one place I am going to try opposite Sim Lim tower tomorrow, and see if they have APC polish kind.
http://www.leebeehuat.com/fiber_pg9.html
cscs3
Is the same, just the connector color is different. It do not have to be green, it can be any color (ie they are all APC polish). But the cable is normally yellow to indicate this is a single mode cable. (laser)
BTW, I bought a duplex 100ft. But ONT use only single connector. So I can sell the other half for $25.
cscs3
[/IMG]
This is single mode, single connector (use by ONT). Not duplex.
Usually, for computer equipment. They use a duplex connector (one for transmitt and one for receive). But ONT use one cable for transmitt and recived (so is half duplex).
cqprime
Yes when i buy it ...it also comes in a pair and i paid 50 for both and one cost 25 SGD.
cqprime
Thanks for the clarification. So u r using the same cable on your ONT ?
Qubicfactor
Green is a convention to distinguish APC polish from the others, since you can use other polishes together with less consequences, but not APC. I don't know where you got your cable from, but are you 100% sure it is APC?
BlackIcE84
great! do let us know if LBH sells it. i'm looking for a 30m length
Qubicfactor
I spoke to one of the staff on the phone, and he said they can also do APC. Waiting for him to reply my email, since he was driving when I called.
cscs3
Yes it is APC. Dont have to worry and it works fine. Take you green housing APC out and inspect. It is just a housing. The color changed depending on which making make it.
BTW,
"Single mode fiber optic cables can be with PC, UPC or APC polished connectors, while multimode there is no APC ones."
The fibre cable itself is the same.
http://www.huihongfiber.com/pdf/sc-fiber-optic-connectors.pdf
