SingNet Fiber Broadband Installed.....
seeyourhead_jiejie
Yeah my first ONT was dead during install. The opened up a 2nd one and it's okay.
They don't lug around too many spares. And honestly speaking, if you tried two and it's not working, high chance that something else is broken.
If someone opened up 6 ONT to try, personally i think it daft.
ya lor.
was told that the mac will get registered and they need to mark the set and put it a side for x number of weeks before it get unregister then they can give it to another user.
xjchew
Got a quick question abt SpeedTest for u guys..
Will speedtest results be accurate after running it multiple times?
I've got a few setups planned to be tested on speedest.net tomorrow and will be using my PC and MAC to do three runs for each setup. That's six runs per setup. Right now I have 8 different setups to test. Just wondering if the results will be skewed after running speedtest for so many times.
Oh and I should be using speedtest.net and not speedtest.com.sg right? lol.
aLpHa-Ev7
i think they both run on the same server.
But do note:
"Note: This speedtest is cater for Internet connection speed up to 100Mbps. If your connection is greater than 100Mbps, you may not get accurate result."
aLpHa-Ev7
BTW,
i realised my IP number never changed since the day i commissioned exStream, and i power off my ONT + RG everyday before leaving for work.
Does the rest of you guys experience the same thing?
aLpHa-Ev7
At last, on SingNet eXplore Home 200Mbps. Running the smart switch setup diverting all VLAN 10 traffic away from 2WIRE.
Using D-Link DGS1210-16, Linksys WRT310N with the WRT looping traffic back to the DGS.
Forgot to take screenies for speedtest, but speeds seem sub-optimal. Tested using two different setups..
ONT -> DGS -> WRT310N -> DGS -> PC
SpeedTest Results: 80DL, 40UL (Had a better result 100DL, 67UP, but still far from max)
ONT -> DGS -> 2WIRE -> DGS -> PC
SpeedTest Results: 150DL, 80UL (Not very optimal too)
Im tinking the WRT310N on DD-WRT is one of the bottleneck so would be changing it. Deciding between D-Link DIR-825 and the new Cisco E4200.
You might wanna take a look at this chart before u do your next purchase:
http://www.smallnetbuilder.com/lanwan/router-charts/view
Razerzone
BTW,
yes, IP address won't change even after power on-off the ONT+RG.
Qubicfactor
BTW,
Has only changed once for me, roughly about a month after commissioning, but still the same ip since that time.
Qubicfactor
guys i really worried after reading around now...can anyone who use 200mbps fibre tell me lets say a legal thepiratebay torrent to dl mmorpg client..hehe....with at least 100 seeds can hit how many mbps dl
Torrenting Ubuntu on my current setup can hit 24mbps.
xjchew
Checked it out before.. lol. DIR-825's WAN to LAN speed does seem dangerously close to 200Mbps. May drop under that if theres WiFi traffic going in as well. Probably gona get the E4200 after my tests today.
But do note:
Noticed that disclaimer only on speedtest.com.sg =/ seems like speedtest.net is fine for testing :s22:
goggles
Continued from part 2 of fiber installation fraustration experience SingNet Fiber Broadband Installation Technical problem part 3
SingTel said that our Opennet TP in my house will have to undergo connection reset with Opennet.The point have some power issues because they did not test properly during our fibre installation on 26 Feburary 2011 at 2-4 pm by OpenNet guys.The Opennet guys that my exPlore Home Sports will be activated after Opennet guys have reset the Opennet TP a few months later and our house will have to undergo connection reset and rewiring of Opennet TP at my house at 15th May 2011.
They tried as last wednesday,tried 2 ONT,2wire 5012NV-002,mio TV Box again.They tried to upgrade the 2wire 5012NV firmware from 9.1.3.25 to 9.1.3.27/Hard reset of 2wire,ONT,mio TV Set Top Box,Change RJ45 cables but no avail.The TP has still no signal.They left at 10:55 am and Opennet Termination Point has no signal and no power.The whole block has fixed except my house.
My exPlore Home Sports plan activation has been clauged by technical problems.I wanted to move from ADSL due to DSL disconnection issues during the rainy weather,mio TV Start up lag which channels play for 10 seconds,then it freezes till 2 min which is the longest.
I wanted to use mio TV/200Mbps Broadband and mio Voice over Fiber,but since the Opennet TP has no signal,I cannot use it and I feel cheated about going to fiber exStream 200Mbps plan which comes with mio TV,Fiber Broadband and mio Voice plan in it.
The billing date of exPlore Home Sports(mio TV Sports with Goal TV,Broadband and mio Voice) over fiber has been affected due to this OpenNet TP failure.I am now waiting for Opennet to fix the signal problem before they come again later next month
I am in the process to complain to SingTel about this technical problem which they are aware off.I am still super pissed off.
The fraustration continues toady...!
what a load of rubbish.
coolstardy
It has been said earlier in this thread.Please read it somewhere around this forums which is posted 3 months ago.:s13:My ONT,2wire 5012NV and new mio TV Set Top Box is under the TV rack with PON cables connected to the TP but cannot use as PON LED on the ONT is still off.I am using ADSL to post this.Lucky,I have my ADSL as a backup till Opennet fixed the TP problem.
can someone put a permanent ban on him or something? He is definitely getting to our nerves...
albertchng
Had a very sad story for SingNet Fiber Broadband Installation experience
Sian,This morning when SingTel want to connect to exStream Fibre,But because of Opennet cock up,no connection to the internet at all.All the connection to SingTel passed except Opennet.At the same time,SingNet disconnect my old 10Mbps mio Home at the same time.They said is most porbably my unit cable to another unit Distrubtion Point and vice versa.
Next appointment will be on 1 month later provided Opennet Fixed that.Otherwise,a week after that.:mad:
SingTel said that the connection for fibre is connected wrongly to the neighbours riser.The Reinstallation will be after Opennet has fixed the connection failure at this block.I am not sure that other units are affected as well.So they take back the ONT,2wire 5012NV RG and mio TV box(with 1 GBPS port in it) and they offered a free 10Mbps mio Home till TP problem has rectified.:(
Before they take back the fibre away,My mother experienced a 2wire 5012NV-002 SERVICE LED was red,ONT PON LED not lighted up and mio TV STB stuck at the purple screen without any broadcast service at all.They spent at my house from 8:00 am to 12:00 pm and the TP problem is still not fixed.
Now I cannot use exPlore Home Sports 200Mbps service(mio TV/200Mbps Fiber Broadband and mio Voice) over fibre.The billing for these 3 services(mio TV,200Mbps Fiber Broadband and mio Voice) will not start today due to technical problems at OpenNet Termination Point.They reactivated my old mio Home 10Mbps at the same day after they left 1 hour later.
I am super pissed off about this service they are handling and I cannot share the speedtest results for now.:(
Can they understand the idea of fibre optics when OpenNet are not ready.I wanted to move from mio Home to fiber,but it is not a success.They tried 6 ONT,2wire 5012NV-002,mio TV STB,call backend,do software upgrade,reset ONT,2wire,mio TV STB,hard reset of mio TV Box,2wire and ONT,the Opennet TP cannot give signal at all to singtel server side and their profile at their end also cannot find my data.
Continued from part 1 of fiber installation fraustration experience SingNet Fiber Broadband Installation Technical problem part 2
This Morning when another SingTel technican came to connect to exStream Fibre,Did the same thing again as last monday,The Opennet TP has no signal again for the 2nd time since last monday.It seems that the last few days,Opennet didn't solve the problem.The whole data is linked to SingTel side except Opennet again.
They tried the same 2wire 5012NV-002/Ericsson T063G ONT and mio TV Box(with 1Gbps in it) but PON LED on ONT is off,SERVICE LED on 2wire 5012NV-002 is red and the mio TV STB stucked at MIO TV words with "An error has occured,please restart your Set top box.
They tried 6 ONT,2wire 5012NV-002,mio TV Box again like last monday,but no avail.They tried to upgrade the 2wire 5012NV firmware from 9.1.3.25 to 9.1.3.27/Hard reset of 2wire,ONT,mio TV Set Top Box,Change RJ45 cables but no avail.The TP has still no signal.They left at 10:55 am and Opennet Termination Point has no signal and no power.The guy tried to install the same plan at my neighbours house,also same problem.The whole block has having an outage on singnet fiber broadband since monday.2 of my friends staying in the same block also facing PON LED on ONT off,2wire 5012NV SERVICE LED is red and mio TV stucked at MIO TV words with An error as occured,please restart your Set top box problem.:(
I wanted to use mio TV/200Mbps Broadband over Fiber,but since the Opennet TP has no signal,I cannot use it and I feel cheated about going to fiber exStream 200Mbps plan which comes with mio TV,Fiber Broadband and mio Voice plan in it.
Can you please stop your whining? :s27:
Do you know that we are pissed with your nonsense cool story? :s27:
