[Consolidated] iPad Accessories and Cases. ::NO SALES ALLOWED::
contacted
Switcheasy Canvas users: Not sure if you guys are finding difficulties closing the cover but I am. When I close the cover, the catch on the underside of the cover rests on the plastic edge. I have to use considerable force to get the catch over the edge to be able to close it. :(
indraven84
I bought the Switcheasy Canvas as the folio-type case, now looking for a secondary case that juz covers the back...needs to be slim/low profile as it will be intended to be slipped into my work bag...
I have shortlisted the following:-
Case-mate Barely There
getDynamicImage.aspx
Griffin Reveal Etch
Incipio Feather
GetDynamicImage.aspx
Tunewear eggshell
Not sure if anyone has these yet, but would like get some recommendations....please feel free to let me have your comments and views...
Can these be use with smart cover
This message is sent from HWZ forums iPhone app
ipporek
Incipio Feather
Oh I'm considering between the combination of smart cover + Incipio Feather or Marware MicroShell Folio. Not sure which would be slimmer. The first will be more ex though, given that I would want the black, which is leather.
filtered
Yes same here. This seems to be a common problem.
Initially can't close at all, but nw getting easier to close. Think need to break-in..... Hahaha
gunners007
I using this casing from The Joy Factory, that protect the back part of ipad2 and it compatible with smart cover. I come with transparent and grey colour and can. Be bought from most of the premium reseller.
Johnteoh
What you can do is to push to out until you can close the cover yet it won't open. I did that to my any now it is easier to close yet won't open when it is in the bag.
htngwilliam
Guys
I got this at Mac Expert at Sim Lim Square 4th floor. I hunt up and down for 1-2 days to get something sleek yet can cover the front and back and also achieve the magnetic soft close function yet must look nice.
After 2 days of searching, found something suitable and it comes in many colors, pink, lim green, blue, grey, black. The material is same as the apple PU cover. Feels great!
falcopex
Guys
Looks great. How much is this? Comes with any SP?
Presto80
Ahhh okk guess I'm not alone then. Hope it gets seasoned after some time.
yupz...just remove my ipad from the casing...
saw some1 post that its damn hard to take out..
but mine still ok...jus tried to loosen the 4 corners and it should be ok..
