Which Graphics card to buy in Y2026
Biff73
Well on one hand it has no VRM/cut corners issues like GTX 570/590 but at the $66x cheapest range a pair of XFX HD6950CF @ $488 offers more horsepower if single GPU set ups are not the only criteria...
HD6850 CrossFire PK GTX580/HD5970
http://en.inpai.com.cn/doc/enshowcont.asp?id=7938&pageid=7658
I agree 6850 CFX is a more reasonable approach for more horsepower,but u should also know that most games do not support Crossfire,single gpu wins in terms of gaming compatibility:D
batuchka
CF scaling and compatibility has ramped up greatly going from HD4k to HD6k actually and previous gen yes i would point to poor scaling and not worth multi GPU set ups but this current gen @@
batuchka
what's the best sub 200 card?
1st hand there is the Sapphire HD 5830 Xtreme $189 and Palit GTX 460 768 $199 but if in stocks i would think $9 over for the Sapphire HD 5850 Xtreme best buy in the lot hehe
wilflare
ah. can't seem to find those prices on PCThemes pricelist
only found Sapphire 5830 for 155 though.
batuchka
Yep saw that in PCT latest pricelist - ask how long warranty offered lor but at that price fantastic buy as all HD 5770 currently are even higher priced but Tradepac seems to have Sapphire XTreme HD 5830/5850 $175/205 so can check that out as well :D
wilflare
think PC Themes one also Xtreme Edition.
if Tradepac's 5850 still available for $205 can hoot sia..
5850 vs 5830, performance difference.. 40-50%?
mradorable
Why do I always see HD 6950 2GB in the price lists in SLS but not HD 6950 1GB?
I can't seem to find it :(
And what is the price?
batuchka
Whoa no lah more like 21% ^^
batuchka
Even in big markets like USA/Europe not much 1GB HD 6950 offerings so small one like SG ....
batuchka
Just research all/any brand card u keen on lor - and weight against current SRP
Biff73
Still,games have a higher crash rate than with single gpu solution:s22:If u are buying xfx,stick with ref model for good pcb quality
wilflare
so batuchka, for ATi cards
5850 $205 is the best bang-for-buck card now
followed by 5830 $155?
anything else in between?
thinking if should go for nVidia instead..
5850 all out of stock unless second hand..
batuchka
The data from Toms, Anand, Guru, HardOcp all points to many assumptions/prejudices for CF/SLI debunked actually with current crop of cards :D
Best Graphics Cards For The Money: May 2011
http://www.tomshardware.com/reviews/best-graphics-card-game-performance-radeon-hd-6670,2935.html
and ya HD 6850CF best option for pricepoint hehe
Best PCIe Card For ~$340:
2 x Radeon HD 6850 in CrossFire
GTX 580 merely warrants an honorary mention at a much higher $490 price point so while single GPU solution in earlier gen sounds logical/reasonable, current crop scaling/price-performance makes this far from apparent hehe
Best PCIe Card For ~$490: None
Honorable Mention: GeForce GTX 580
batuchka
Refer to earlier #3337 post lor :p At that price range the 768M GTX 460 would be an option
wilflare
thanks for all the recommendations
decided to "save" my cash and got the 5830 instead ^^
