Samsung Galaxy S2 - Guide to Rooting your phone (Always evolving and ever changing!)
attarturk
Any idea guys, my cwm and titanium backup refuse to saved in my external sd card
also guys now i am with litening rom 5.0 and stock kernal kg6 (to remove the yellowntriangle) but my cwm wont boot instead it goes to android recovery mode <3e>
V
victorlht88
Guest
cwm is based on ur kernel.
with stock kernel then of course there isn't any custom recovery.
you gotta flash a kernel with custom recovery.
attarturk
so what kernal should i flash in order to get cwm when im on litening rom?
How do i remove the yellow trianle then??
Warglory
Guys, I read that there is a counter for when flashing stuff on the phone, and that the only way to remove the counter (and the yellow triangle when using unofficial firmware) is to use a certain usb jig.
Is this true?
Also, is it necessary to reset the counter before sending the phonew for warranty or will just unrooting do the trick.
Sorry for the questions.
attarturk
Is this true?
yes you need to buy the jig to reset counter it cost rm30
kaydee
Hi guys,
I have been reading this thread and need some help.
I have flash my S2 modem to KG5 and kernel version is on Ninphetamine 2.0.5.
if i want to include CF-Root..
which file should i choose to root? (print screen as below)
mynameisjon
Hi guys,
You're already using a kernel that includes root components. why would you need CF-Root?
mynameisjon
cos i want to use titanium backup and hv root access.. which i cant currently.
ninphetamine already has root access.
Did you click allow when the super user prompt came up when you first ran titanium?
Check whether you have "Superuser" in your app list.
if not just flash nimphetanime 2.05 again and it should be fine.
V
victorlht88
Guest
you need a kernel with root to use cwm.
if you want to remove the yellow triangle + root, then use a jig.
get it off ebay.
kaydee
it says error and could not acquire root privilege.. etc. cannot be right? ok I try to flash again
Nitrile
ninph kernel is not rooted leh.
if you go from stock to ninph through odin, your phone stays unrooted.
