Helloo, So far what modules had you taken? Is it tough or difficult to cope?
done OB, the two java, the two math, ICT219, ICT220, done the two accounting, done COR160 and GSP165.
currently doing stats, management, marketing mix management, ICT321 and COR167.
as for difficulties...
can be quite stressful at times cos while other ppl can simply settle for just a pass for their modules, you have to score really well cos it is a direct honours program.
and it can be pretty annoying if you happen to have group members in group based assignment team that is not doing his share of the assignment at 100% cos he is simply contend with a pass.
apart from that, IT and biz are like two sides of a coin, totally different and no link with each other. the grading criteria, the projects and even the knowledge itself is totally different and no link with each other.
sometimes it feels as if you are actually doing two seperate degrees concurrently.
those that have done some biz-IT diploma in poly should be able to understand what i am talking about.
