Skyy
- Oct 27, 2001
so the new galaaxy nexus will be in before end of 2011?
or in jan haah
Samsung always said it'll be in Jan.. so keep waiting..
or in jan haah
Your app will automatically download into your new phone once you sign in your gmail account.
Yes, of coursecan u have 1gmail account sign into 2 Android pone if we own 2 ,?
Oh come on, your English is already pretty bad...this one is like sh*t.can u have 1gmail account sign into 2 Android pone if we own 2 ,?
iirc those using wet application usually use quick drying ones like alcohol or lighter fluid. But used in sparing amounts, not so much that it would seep into any ports.Hey guys, anyone here have experience in applying wet screen protectors? I decided to get the XO skin for the GN and it's going to be the first wet application for me.
I prefer to use dry screen protectors as they seem safer but the cheapo one I'm using now is rather poor quality. None of the branded dry ones seem to go to the edge of the screen so now seems like wet is the way to go.
Any precautions when applying wet? What about liquid seeping into the speaker etc?
Oh come on, your English is already pretty bad...this one is like sh*t.![]()
Ah ok. Well problem is there's a cut out for the speaker at the top so I'm pretty sure some of the liquid will seep into it as I squeegie away the excess liquid. Not sure if it's safe.iirc those using wet application usually use quick drying ones like alcohol or lighter fluid. But used in sparing amounts, not so much that it would seep into any ports.
Thinking of getting one too. Btw, you used any of the discount codes?
Yup I used the SPRINTXO code for 30% off. Shipping is around 7 USD though. So total is around 17 USD.
I chose XO skin because there's no orange peel texture like the other wet type protectors.
The discount code valid until when?
No idea when. I got the code while browsing the xda forums. There's a 20% Christmas discount which ends by christmas and there are some 50% discount codes but those seem to be only one time codes so other people can't use.
xochristmas20 is 20%, SPRINTXO is 30%
