I tried SimiClock with Adw Launcher. Still playing around with the tablet though..
Go launcher Ex kinda lags up the tablet..
Hi guy need some advise here.
I try to connect my 10.1 to my PC by using USB cable. But cannot link to my PC?
I had change the setting Development >>> USE debugging liao, but still cannot ?
Do you guy come with this Problem ?
Right now i am using airDroid. Can you guy help me ....![]()
have any got the problem of slow surfing of net using tab? it takes forever to load on my tab and i keep on having problem opening LETV!
any idea?
any idea?
Hi all, just gotten the 10.1. Question for me though is where can I find the accessories for the Tab? Since most of the shops doesn't have it at all. Another thing, when I did my initial startup, I was given a choice of using it as; an Android phone, Desktop, iPad, iPhone. Now when I wish to change that, I'm unable to find that anymore. Anyone has an idea how I could reconfigure that again?
vivo sell the accessories
u are using an android devices
how come u are seeing ipad, iphone setting?
impossible rite?
i dun see it in my tab btw
Anybody can recommend me which calender widgets that show montly? I the stock calendar widget is called Agenda and i dont like it that to see monthly must press on the top left corner of the widget. If only I can have something similar to Galaxy Note's calendar widget.
