The Denim Thread [Read the first few post before asking questions] - Part 1
1nf1n1ty
Dan_Bo
any web/shop that sells a.p.c buttons? realized that the only way to repair it is to get new ones :(
Dan_Bo
Just get any button la why must apc
feels weird :s13:
actually i'm not very sure about the durability of other buttons as my jeans is still in the stretching stage. scared button fly off again :(
platee
feels weird :s13:
happened to me before on my apc. Guess apc buttons are not that strong. I replace some old bronze button till now still good
hosehbo?
guys, what shoes do you match your jeans with? got a pair of dior 19cm but unlike the folks at the dior thread, i'm not so well to do that i can afford expensive shoes.
thinking of getting a dr marten's mid-cut or some mid-cut to pair with. will it look weird?
btw the fitting isn't those skinny type as i left the dior unaltered.
F.Torres
Go with chucks hugh cut. Affordable and classic.
LouisSaha
i've repaired mine at Haute Alteration. Most alteration shops should have such services. You can try Clancy at Far East Plaza. They might be cheaper.
Haute alteration is really good.
Great quality of fabrics n their workmanship is great too.
Just tad abit of pricey. I did a couple of replicate n alteration services at there too. Didnt regret la cause the job was nicely done.
vincentwkh
Hi guys,can someone enlighten me the difference between apc new cure femme and homme version?is the cutting the same?and does it differs a lot between the two models?
platee
femme version got no space for bola
vincentwkh
What about the thigh measurement and leg opening!is it the same?quite confused as the one I tried at front row is the new cure femme version!so I'm afraid if I order the new cure in homme version it will not be fitting
platee
Same. New cure is a good cut. Just go two sizes down and it will fit great.
