Galaxy Note Accessories
whatme
Mod already come here and post before recently about no buying and selling already.. :look:
imacbie
Anyone using Sweet armor-note bumper? Is this bumper will make ur phone to have scratches???
this i can help answer you,
am using a set myself,
no, the bumper will not make my phone to have scratch :)
it fits pretty snuggly.
Akai Ryu
imacbie
Does it make the phone to be much thicker?
i wouldnt say thicker, unless u are using it together with the aluminum bumper. it adds a little bulk but at the same time, the bulk provides the xtra grip.
the naked phone is sleek, yes.
but with the alu back and bumper combo, the overall result is pretty good.
IMO, YMMV
Akai Ryu
Been waiting for this case.. Mind to share where i can get this case? Used this type of casing for my Blackberry and survived most free falls!!
was it easy to remove when u were using with BB?
edited: i revisited the YT vid of this case and it seem to add quite a bit of bulk, moderately easy to remove phone but Spen extraction may have some problem
davi502
IMO, YMMV
Oh, I assumed there's only aluminium bumper. Didn't know there's non aluminum ones.
ProGamer84
i am only talking about the aluminum bumper
I did remove my phone from the bumper and inspect for signs of abrasion. but did not find any.
Do u knw i having some scartch on it? so i dun think is a good bumper... i will say SZLF is much better den Sweet Armor-note
ryker
SZLF is the same as Sweet Armor.. They are all OEM ed by the source, just marketed by diff companies
imacbie
now i knw, because u just mentioned. :s8:
let me guess, the scratches are along the glass bevels/edges?
just make sure the phone is fully sitting in the bumper before sliding in the front piece can le.
and like the post above mine, they could be from the same OEM
