how many reshelling or considering to reshell their TF10?
freewayfight
Ya Lor, heard that the GR07 is somewhat almost near TF 10 standard. Anyone have any impression and comparison about that?
cowsux
anyone chose opaque white for the color or the iem? i wonder if it will decolourise or turn yellow (especially the tips) over time?
btw i'm reshelling with um
KahBoom
Heard it'll yellow after maybe 1 - 2 years since its acrylic afterall. By that time u would've reshelled it again haha. If you take good care of it maybe it'll take longer?
fatthumb
I have TF10 but currently pre-ordering GR07. For the price now, I recommend you to hoot GR07 since there is no guarantee TF10 will be comfortable enough in your ear (imho) :o
Kazeshini
Hey guys, I got a question.
Has anyone tried reshelling SF 5 PRO? And adding an extra driver to it?
Is it worth the reshell or should I just get TF 10s instead?
KahBoom
May be worth a try? Sf5p is dual driver right? But getting an amazon set tf10p + reshell would be better off than sf5p +1 reshell since by adding drivers there are risks involved that may change the sound signature drastically and you may not like it. All in all still up to you. Try out the tf10p at jaben first and then do your own leap of faith :)
freakzoid
My tf10 ear tip fell off. LOL. excuse to reshell now? heh heh. I still can force the cap back on and listen though.
fatthumb
Do you change your eartip often? Can use a bit of epoxy to glue back?
My concern is after re-shelling the sound signature maybe different :o
freakzoid
Not that often! )= Ah I'm not too concerned about a change in sound sig. If I do reshell I'll probably add an additional mid driver so the sound sig will definitely change anyway.
fatthumb
Of if that's the case I should say go ahead then :s13:
If I ever re-shell my TF10, I think I'll add low driver to make it more boomy =:p
