Rooting will never affect your flash counter.
If you want to install custom rom and don't want to alter your flash counter, then just use mobile Odin and you can just flash off android.
Bro then how come ppl nid to buy USB jig to reset e counter ar? Is it use mobile Odin then safe Liao,dun hav to worry abt flash counter?
Wat to use to backup the stock settings (in case nid to go bak samsung) before rooting n flashing?
N wat u mean by "flash off android"?
Sorry for the many qns....jus a android noob here
