Qubicfactor
- Mar 26, 2003
ok. am going back to default Asus firmware. this firmware has 0.5 to 1ms better ping, but when i torrent the upload stays stuck around 380-450KB/sec.
changing back to default firmware i get my usual 800KB/sec - 1MB/sec seeding speed on my fibre.
hmm, I noted the same pattern too, with the 400KBps upload ceiling for torrents. then again, this 1.0.1.8ep1 is the first to use a different kernel, so maybe there are some bugs brought over.
will try to tweak to see if any padavan default parameters are causing it, otherwise it is a bug worth reporting.
ps: if you can, test the previous 1.0.1.8dp3 and see if it occurs; I dont torrent that often, and its not often i get to see people leeching off me enough to see a ceiling like now.
