cyberwave
- Sep 12, 2010
EH serious bo?! How come I saw only 29th earliest can buy???
Would have gone down today if I'd known...
seeeeeee
nobody knew
Wonder who will be the ones posting tonight... all power to them and 3570K!![]()
Already informed you guys much earlier in post #376 but you guys didn't read between the lines... of course, cannot say it until too obvious also lah.![]()
seeeeeee
nobody knew![]()
must b parallel import one...coz local distros still under NDA so shops under them will hav to wait till the 29th date. Parallel importers have no restrictions on them other than the one Intel imposed but of course the buyers have to depend on the parallel import retailers to honour the warranty lor...Had to keep it lower profile so at least my informer can get his chip too mah, if I make it too obvious and he can't get his chip, I die liao... lol
Eggy88 said:I have realized that the thing with these chips is that temperature tests need to be done over an extended time. After 5min i saw 20c lower max temps then after 30min, even tho the water temp did not change much. The 6x120 GTX is able to keep it to ~4c air vs water, and the water temp only rises with ~2c during load. But it looks like the chip is slowly building up heat. With the 3770K's and HT @ 1.35v i got temps in the mid 50's after 5min, 10min was high 60's, 20min low 70's, and @ 25min it had jumped up to ~77c before i shut it down.
The tests that are showing prime runs on air/water after 5-6 min does not mean a thing. If they have air runs @ 5min with 80C it will for sure hit TjMax after 30min.
Think should be horzontal line to be keeping with the orientation seen in the photo shown in post #393.
But may not make much of a difference if the rate limiting step of thermal transfer is actually at the core -> IHS interface and not the IHS -> HSF interface. The fomer is more likely since early adopters have complained of heat build up over prolonged stress loading even with chilled water at 10C.
Really just too bad for now.
does heat issue affect non-overclocker?
advisable to use 3rd party hsf?
