Hoot Club! Post Your Technology/Hardware Related Purchases NOW! - Part 2
gallagher
for temp i using the HWMonitor, the red icon
noise lvl i also don't know use what to measure
so far mine's acceptable lah
dirtysock
Sitting in my new 13' MBP now :D
Mach3.2
solved it? was it a hardware fault?
had this problem quite some time ago, found out that it was the 100mb MBR partition (or whatever it is called --- System Reserved) causing it. So delete all partitions + fresh install again solves it.
I did a secure erase and start over again, still have the BSOD, so went down to PCThemes at 12:40PM on Sunday to change a new one, PCThemes is kind enough to exchange a brand new one for me:s12:
Ferolare
what i hoot'd with mr elite banker
(thank pete he didn't manage to tempt me into go for his 600t white :s13:)
MacClipper
eminus
[IMGhttp://i186.photobucket.com/albums/x167/ferolare/operation-ivy-bridge.jpg[/IMG]
bro I think your 612pwm and ms-1 casing might be a tad too tight?
persentio
Nice! can that green LED be disabled? imo that is the only eyesore for me:s13:
Not sure... Like cannot leh lol. As long as got power supplied it will light up.
Jason.OnEarth said:
Hi, How much does it cost? The CPU cooler looks interesting, if 50~100 I'm ok.
SRP $199. But you can bargain for a bit cheaper.
Gattberserk
$199
Anyway any idea what LED lighting does Phantom 410 comes with?
Any way to differentiate them between different LED colour?
Can, easily done.
Just enable this simple extra-UEFI feature as shown below. :D
Non adhesive black tape? :eek:
