ipadxcell
- May 10, 2011
Ya should be green, even though I dun have the phone (tried in Samsung Shop, but the image quality so way better than yours
Focusing faster than iPhone4S?
Those who said starhub wouldn't care about our complain emails --- they got back to me saying they would extend the gift set to me. Too bad I went with m1![]()
i did wait for the green box to appear and the tee-tee sound before snapping thou.
how about u try take a pic with yours of your tv about 3m from it and post up to compare with mine in low lighting?
thanks
Looks like something's on the lens. Plastic? Oil? Cannot be that bad right..
For prominent objects in low lighting, center-weighted metering works better
not only u must wait for the green box, did u double check on the screen that the pic is sharp before hitting the cam button?
mailboy;67076993 mine looks gd:D[/QUOTE said:yup. yours good.
how far did you take the pic from your tv? got 3 metres?
which mode/effects u use?
Yupe that's the one. Bought mine at Challenger AMK Hub for $122 after member discount. I'm sure SLS will sell cheaper, but too lazy and too impatient....![]()
There have been many complaints about the gs3 functioning poorly in lowlight conditions.
But none as bad as that one lol.
yup. but mayb my hand may move a little when i press the button. it was the same i did with ip4s.
i'll try again tomorrow night. s3 flat liao.. time to do charging...
wah lau eh, first is never take out plastic, then now say maybe shake when pressing.. sounds like user problem to me.
aiyah most cam phone will perform bad in low light unless it a real cam
i already took off the plastic and retake the pic. did many shots, still the same leh....
that why asking for help of s3 users who also have ip4s to do the same test to compare the results. it is the far distance shots that shows the difference. That's why i tested it by sitting 3m (yup its 3m as i just took the tape to measure the distance) from the 40inch tv.
i just want to make sure it is user problem and not the hardware issue.
Thanks
So they called you personally?
