WonderGirl
- Mar 17, 2003
Hey guys, how do you all get the free 50GB upgrade from Samsung for dropbox? Can somebody please advice again. Thanks a dozen!
sign up first. Then check your email.Hey guys, how do you all get the free 50GB upgrade from Samsung for dropbox? Can somebody please advice again. Thanks a dozen!
The salesman in the shop broke the side of the catch at the top centre a little bit when installing the battery.Then if use the extra battery and external charger need to open the cover often, not sure it will last how long.
to remove microsim..make sure u push in the card and it shall eject~ just like how you insert the micro sd card~Mine has a small crack at the side where one of the catch is. Noticed it on the first day I brought it out. I have no idea how it can appear cos I only opened the back once to insert my sim card and battery before that.
Sad to say I find the build quality of the S3 to be much worse than S2. I hope Samsung or others will come out with a replacement back plate. Meanwhile just have to minimise opening and closing the back cover.
By the way, what's the easiest way to remove the micro SIM card? Mine feels like it's a super tight fit and i think the only way to remove it is to use a tweezer.
I just found out today, sign up and install it on your phone. They'll send you an email linking you to a "get started" guide where you have to finish 5 out of 7 simple things like reading the quick tour guide etc which will take around a minute. Then you'll get your free 50gb![]()
Anyone got prob like me configuring the mail for yahoo? My hotmail is seamless but yahoo kept having unable to connect to server. Can any folks help?
Got a 64GB cl10 for $78.
No lucky dip nvm.![]()
Where do u sign up from? Of I m existing Dropbox registered user, do I get the free upgrade too?
u just need to link a dropbox ac with ur s3, will auto give u 48GB storage free for 2 years
yahoo mail does not support POP3. need to sign up for the premium and pay 20 bucks. which is why i switched over to gmail.
Just got pebble blue from m1,the storage device show total 11.35gb,is it normal? As i'm new to android phone,didnt know that it took out so much space?
its normal
16gb will not give u full 16gb usage after formatted
juz like 1TB (1000gb) pc harddisk, after format become 930gb only
have to minus off the rom, apps, bloatware also
How to make the contact picture grabs the Facebook profile pic automatically?
