DigDub
- May 21, 2002
i am surprise you got a lot of information about these camera removal...
do you happen to be in this trade?
me not in this trade.
I read ics is laggy and memory management not so good. u using China, Cambodia or Malaysia ics? does non ics apps have 3 dots at the bottom? the touch butttons functions remain the same after ics?
For now M1 is
Ace
S2
LG Optimus L7
Honor
Starhub
Honor
how u upgrade? from stock direct to Cambodia ics?
U can do a search of my post in this threat. I have put up a simple instruction on how to do it. but u need to patch your stock GB first before u can upgrade to the ics. else u will face a failure at stage 2.
Looks bearable from review videos.nice but i think will lag like hell pls give review
ics makes usb storage as mtp now instead of ums.![]()
Honor ICS has usb mass storage like the one in gb.. I dont think there's MTP as I cant find the settings.
I connected to USB and can only choose mtp or ptp option under the pull down menu. u using the Cambodia ics?
also after restart, the ringtone and SMS tone will be set back to default. browser perform very laggy also. should have stuck with gingerbread.![]()
