Command schools.
deathman91
Is it worthwhile to go through another tough training of 6 or 9 months to enter SCS or OCS?
Is it true that SGTs and officers need to serve a longer reservist term?
May I know what would a NSmen role like in a combat unit? Is it like a dog, similar to a REC in BMT, following orders from SGTs and officers? Would like to know likewise for SGT & officers roles in a unit.
reddevil0728
Subjective
Officer yes.
Something like that. Though sgt is sandwich class.
agentxq49
Subjective
Officer yes.
Subjective whereby if you have alternatives, like study for SATs, maybe give tuition or something, then don't go command sch. for most ppl, its more worth it to go cmd sch cause you aint just sitting down waiting for time to pass for the 2 years.
sgt better life in 6 months training, not as good life as officer after training, but no extra reservist. its your choice. if you go to OCS, you can highlight to xfer to SCS in the first 2 weeks. I had 3 guys in my wing just xfered over.
negativzero
If you like to chiong sua, by all means go for SCS or OCS. If not remain as a man for the rest of your NS life. Most impt thing, if you want good life in your NSF days, just follow instructions properly, even for specs and officers, cos there is always someone bigger in rank than you, the rest if up to luck if you get posted to a good unit or not.
Reservist time is slightly different. Everyone call each other by name, not by sir or sgt. Again how well you enjoy ur ICT depends on how good ur unit was in NSF time.
deathman91
I don't like to Chiong Sua.
The most important reason why I am complatating going to command school, is because I believe commanders would have an easier life in units? If that's not true then maybe I will give up the thought of going.
Also, I believe we can't choose units right? But can I express interest? I actually wish to be a specs to train REC in BMT.
negativzero
No you won't get a better life. Every rank of NSF have their own problems. And there will always be someone one rank higher to cause problems for you. Also take note, for the same offence committed in NS, man will get 1 extra, spec will get 3 and officers get 7. With great power comes great responsibility ;)
Honestly, if you want good life, just keep a low profile and follow instructions properly.
You cannot chose unit but you for sure can say what kind of unit you want. But if you score well in your training phase, there will be a higher chance of you being posted to a good unit or the unit which most likely matches your preference.
Kyoji83
I tell my younger brother to become an Officer or Man but never become a Spec.
NSF Officer good cause have $1K++ allowance while NSF Spec have similar responsibility as officer but similar allowance as NSF man.
Man(NS) reservist good cause is mostly main body and just follow orders or relax while Spec(NS) have similar responsibility such as advance party doing planning which is same as Officer(NS) but without Key appointment allowance.
agentxq49
If you go OCS or SCS, you can somewhat influence your posting a little bit, like do staff or instructor or PC work. but ya, in NS, they all have their problems.
derp2806
i thought of going command sch before too. but 6 months of nonsense i dont think i can take it. but combat fit vocation will get posted to what kind of units?
Blitzcy
It is best to go to command school for me. Better then staying at one place, doing the same thing for the 2 years of your life, as a man
mrpoker
combat fit means u can be posted anywhere loh.
but not commando or ndu since those are mono intakes.
reddevil0728
thats 1 of many reasons.
negativzero
does our physical and combat performance during bmt affect where we posted to??
Your performance in BMT will determine if you get posted to command school or not. As far as I know, the vocation you will be elected for is chosen by the aptitude test you do in CMPB before enlistment.
reveton28
the aptitude test that ure referring to is the one that we have to answer the questions right? at the end of the test i think i cock up...the part where they ask how long i took to finish, i put 5-10 mins and then whether the time given is enuf i put no....which is by accident...haiz...hope this wont land me in some shag vocation...
mrpoker
isnt that part more like a survey?
the aptitude test is all the IQ questions.
thesoftmint
honestly the best place after graduation is a HQ
dam slack 90 percent of the time, and sommore do clear work and get paid more then twice then a nsf cleark
2lt is like 1.2K
3SG is like 960
pte-cpl is 500-600
cjfalk
actually it's (usually) far more worth it to be a combat spec/officer than a combat man.
1) training in SCS/proterm can actually be more slack than training in the combat units. for OCS though of course more shiong la.
2) if you are a combat man, chances of landing a training/admin post is virtually nil. while as for SCS/OCS, this is considerable.
3) pay differential between spec and man is actually quite big (300+), bigger than between spec and officer (200). very useful if you want to save up.
4) generally as a spec/officer you will have far more freedom/less regimentation in the combat units (e.g. don't need to wake up early everyday, OTOT canteen etc, no need fall in, leave application easier to clear if you want to apply outside of designated block periods). of course some units are more strict on the specs than others (some treat specs more like men, while some treat specs more like officers) - but generally life as a commander is always better than a man.
also, those that say that spec is sandwiched/lousier life than officer - may not be the case. PC/PS often kenna alot of nonsense like meetings/bn command team cohesion/paperwork so often have to stay back and do more **** while sect comdr can pretty much finish up training with the men then leave. not to mention COS/guard com duty is still more slack than BDO/BOS duty.
cjfalk
also I think people are alot of misconceptions:
1) don't think the vocational test chooses the vocation for you - merely eliminates those that you are unsuitable for. then when your posting comes you will be randomly chucked into a vocation you have the clearance and qualification for.
2) whileas officers are liable till reservist till 50, if you are a PC in reservist you will just do your 10 cycles with your platoon and MR. the added ICT usually only affects those holding OC/PSO and above appointments (plus CSM and above for specs). PS have no added reservist. accordingly those holding PC appointment have no added allowance.
3) many often talk about "responsibility", but as an NSF it is hard to really place any much responsibility on you because face it, you are a still an NSF and what can they do to you if you screw up? at the most scold, charge, sign extra. but nothing of great significance. so in the end the actual responsibility usually falls on the OC/CSM plus the regulars in the coy because it is their job and livelihood. no matter what rank you are, as an NSF you are just there to make up the numbers.
