Galaxy S3-Accessories for Humans!
Skyy
wah lau eh, the areas that are not protected by the SP is so small only.. so heng will kana scratch at that few mm area meh?
JAson1980
just received the MO from victor. the plastic container puts "US LTE version", then discovered that this has the tightness issue reported so far. pressing on the casing results in my power button being pressed as well. my phone restarted as well just now. hopefully it will expand in the next few weeks so that it won't be so tight
Yeah, i have that problem too. Sensitive power button.
I can see the buttons area bulging. :s22:
tradesteady
Yes,ROCK Case is very impressive with its design,I'm using the ROCK Quicksand Galaxy S3 Case at the first seeing on it...
Gray Rock Quicksand Case for Galaxy S3 i9300 with Matt Cover - slickfans.com
adix_82
privacy sp will make those white parts "black" cos of the flim right? doesnt really match white s3 =X
The privacy sp will cover the Screen part only. Leaving other white part expose. So ur set will have 2 colour tones.
lccpor123
http://25 media.tumblr.com/tumblr_m7o7teuUPm1rr9fyso1_500.jpg
[IMG]http://25 media.tumblr.com/tumblr_m7o7teuUPm1rr9fyso2_250.jpg [IMG]http://25 media.tumblr.com/tumblr_m7o7teuUPm1rr9fyso3_250.jpg
[Link removed]
[/QUOTE]
Stop promoting your products here. Buy/Sell posts/threads not allowed.
IF not we all leepork le :s22:
rethaFrey
I believe it depends on luck, my Neo hybrid Lumi blue has the extreme sensitivity on the buttons which cause accidentally push but not my Neo hybrid Color White..:s22:
i suspect only Lumi series got this problem cos mine is lumi as well
fongwk8
Haha I'm still patiently waiting for Victor to come up with prices for the Curved Crystal screen protector MO~~ :s13:
XasakuraX
dude, i suggest u read properly the front posts b4 jumping to conclusions.
i m refering to the space left unprotected by the 3m privacy sp, not the usual 5mm border left by most sp in the mkt :s8: 3m privacy sp only cover the screen part.
on the heng suay issue, u nvr know ;) murphy's law :s13:
interested too. hope price is gd :D
natgw88
for those using neo hybrids and facing sensitivity issues, if you are brave enough, u can cut off the bulge on the inside on the case.. it will decrease the sensitivity quite significantly.
Nichi
quite interested too but dont dare to apply it on my own...
curved protector i think like quite hard to apply
V
victorlht88
Guest
still not available yet.
according to sources from korea, it will be available on 13 august and I will be chopping a few sets!
JAson1980
Thanks bro you solved my problem!
No more sensitive power button!
natgw88
np.. the case works alot alot better after cutting it off.. at least the buttons wont be activated just by holding the phone. :D:D
good to know that its working for you as well.. congrats and enjoy the case!
