[Official] All SSD Promos and Deals! (Strictly no referral link)
herwwx
Hey guys, if running the ssd on sata2 connection does the getting the fastest ssd make a difference?
Or sata2 makes the speed of the all the ssd bottleneck thus the speed of the fastest ssd will be limited.
If tats the case i might jus go for the cheapest ssd either the strontium or the transcend.
wackykid
it's easy to imagine... if you drive a ferrarri on a road with 50km/h speed limit... then max you are going to get is 50km/h even if ur ferrarri can do 300km/h rite...??
same thing... SATA is the road... and the SSD is the ferrarri... which ever is the slowest will be your bottleneck... so if u use a SATA3 drive on SATA2 system u are going to get SATA2 at best....
so you can say that no point getting fast SSD drive with SATA2 system...
however there are also other things to consider... if u think u might upgrade ur system in near future -- which would certainly have SATA3 at least... u probably would then transfer ur SSD to the new system and so the new system can make use of the SATA3 speeds.... so u might still consider SATA3...
also cheap... speed... are only some of the factors to consider when getting SSD or any equip... u might also consider other things like reliability... support so u may consider which brand of SSD you would get...
regards,
wacky
jaywalkra
regards,
wacky
This is the reason I went with Intel 520, solid 5-yr warranty. My other choice was OCZ Vertex 4, but when I think of their distro hor... :s16:
herwwx
regards,
wacky
Thank you for the reply.
Greatly appreciate it.
I want to install the ssd on the ultrabook. And read online ppl manage to run on sata2 oni.
Hp envy 4t
datsunking
Not really sure on how to use this program but this is my result on the strontium hawk 240GB SSD... using sata2 on my old i7 dell xps
Hugo
I wouldn't. I would either go with Samsung or Corsair's NGTX :s22:
i stuck with samsung 830 as i order the laptop kit with a usb data transfer cable which i wanted and partly also amazon is very efficient and shipped out the drive before i can make any changes :s13:
herwwx
Any opinions on the drive? Planing to get tis too since its on promo and it's a 7mm drive.
Did u order from the promo?
If yes hw long it takes to ship.
Promo is 170usd
datsunking
Promo is 170usd
Felt good cos its my first ssd... Took 2 days n its delivered in front of ur house... But no sata cable, so i had to go buy one...
watzup_ken
I need a 7mm ssd.
Very few choices out there.
That is true, go with Samsung or Crucial should be fine. To be honest, I am skeptical about Sandforce powered SSDs, even they are from Intel. That is the reason I went with Samsung this time instead of Intel. :o
