Samsung Galaxy Tab 2 - 7.0 Thread Official (Local & Amazon sets)
JAson1980
Is it the UHS1 card with the Android logo on the packaging?
Those don't work well with formatting I'm afraid. Personally I trashed 2 of those before getting a Class 6 64gb online which worked fine on FAT32/NTFS. :(
ya this card... nvm, i swapped out my S3 32gb card and used it in the tab instead,
kennyboy
Remember, to be safe get a Class 6 or 10 64gb card. Don't get those that's rated UHS1. Sadly, most of those available locally are UHS1. :(
kennyboy
but i am using that UHS1 .. the one with the android pix
I'm just speaking from experience.....me and several guys on XDA kenna that one before, higher chance of cockup. :(
But there's no way to know for sure until one tries, so....anything goes. :)
Yours can do all file operations to the card? Copying files via usb cable?
JAson1980
Whoa, managed to format my sandisk 64GB SDXC card to FAT32 using my office card reader.
Crap that my sandisk imagemate USB 2.0 cannot even read/format my card (WTF)
Now my tab 7.0 can read the card and i am transferring my movies over. :D
yh_lee
May I ask is your Tab2 7.0 with internal 8Gb or 16Gb ?
If mine is 16Gb, can I add the 64Gb card too and make it 16+64Gb ? (i understand some overheads are used).
just wanna be use so as not to waste a 64Gb card...
Do you have the exact brand so that I could go and get one as well ? I am using wifi only GT-P3110 tab. Thanks
JAson1980
I am using the tab 7.0 wifi 8GB. yes you can use the 64Gb card but you need the correct reader to format it to FAT32. I am using sandisk SDXC microSD card. most retailers carry the sandisk with the android robot on the packaging.
yeah82
hi guys, ask u a noob question here. can i just my s3 charger to charge my tab 2 using the usb cable? i know that the output of the s3 charger is just 1A whereas the tab 2 charger has an output of 2A, does this cause any harm to the battery of the tab 2? :s12:
patt0n
Hi Jason,
May I ask you a few questions about how much you bought this card and do you need to "root" the tab to use this 64Gb card?
Would also like to ask if you bought it in stores here or online ? and the reader you use to format it to FAT32 ?
Thank you very much,
Patt0n.
GreenArrow2002
There is a Jelly Bean OTA (4.1.1) for our P3100 from Malaysia. You need to have a stock recovery to flash this.
joelchan
bought some accessories
went to House of Mouse at Suntec
*1) Galaxy Tab Connect Kit S-K03 (for USB devices) : S$5.90
*2) Sandisk microSDHC with adapter Mobile Ultra for Android 16Gb : S$19.90
*3) USB data cable : S$7.90
4) Plastic cover/case : S$18.00
*tested working
JAson1980
*tested working
what case is that? did you buy? any pics?
joelchan
JAson1980,
that's the one. Maybe not 100%. it's same type, plastic ones. There's also 'leather' type too
Joel
