damienloh
- Jan 1, 2000
Don't wish to order for something don't know when will get it. Also no price incentive to order early.
Took me 2 days to upgrade to JB due to the driver issue also...
For step 3, did you choose Let me pick from a list of device drivers on my computer -> Have Disk -> Browse instead of Search for driver software in this location?
Is your unit CZ version?
Thanks for your patience. Managed to get pass step 4 with code 10 error displayed. Now stuck at step 5 - can't power up the tablet by pressing the power+vol down buttons with usb cable connected. Also can't power up when I tried the power+vol up which I used to go into recovery mode.
Think mine is CZ version as the there is 'CZ' in the serial number behind the tablet.
hmmm, users with ainol fire, do you have popping sound or mosquito sound?
My advance finally decide to spoil, hence, deciding between MIC tablet or n7.
lol bro, interface should be somehow acceptable ba, I dun mind minor stutters, am looking at gemei g2 any opinions ?
Faced the exact issue as well... can't remembered what I did exactly to resolve it.
If not mistaken, it doesn't matter if u cant boot up to recovery mode during power+vol. Check ur rk3066 tool while power+vol whether it turns green. If not, turn on or off USB debugging n try.
Once done, u r a step closer to JB.
Thanks. Really appreciate your help and patience!
Finally managed to flash to JB.
Instructions are sieved from subsequent posts in slatedroid. After step 4, off tablet. Run Rockchip Batch Tool and load img file. Unplug usb cable from PC but, not from tablet. Then press vol up and hold it while plugging the usb cable back to PC. Rockchip Batch Tool will now recognise the tablet and show the green box. Just click on upgrade and viola - JB!![]()
Any N90 users who have problem loading youtube HD videos fully? Some youtube HD videos will always stop at the same point.
Read from slatedroid that using youtube 4.0.8 for JB will resolve this issue. Installed this version and still faced the same problem. Any solutions?
Hi bro, able to publish the procedure here to benefit bro whom are interested to hook this N101?
Just received my N101. Feels good on hand.
