netzach
- Nov 28, 2011
Powersupport sp are out.. but only in ebay and they are going for $64![]()
WAH! $64 for SP!! DAMN EXP SIOL!!!
WAH! $64 for SP!! DAMN EXP SIOL!!!![]()
Netzach bro can buy from japan lol 1648 yen![]()
Just gotten my Neo EX silver one...the rubber seem abit different den when i was using it with my iphone4..seem like more hard kind and the case overall feel "fatter" compare to my iphone4 one...anyone have the same tot?
But still feel it is quite worth the money at 49.9$ with the front and back protector... got it from amk hub basement...
hi bro, do you remember the name of the shop or at least near which side? same floor as cotton on OR ntuc? thanks.
moi wifey's banana case set-up...
I like this desmay casing alot. How do I get it from Casper as you mentioned?
hey haha, after 2 weeks or so let me know if the white silicon turned colour . . hopefully not~ z
erm...the same level as OCBC bank singtel etc.....is those small shop along the main walk way... the shop is opposite a shop selling girls hair rubber bands etc....![]()
Perfect. Good jobLooks good right? The cutting is very good and it fits all the buttons accurately. I like the matte finish as it doesn't make my iPhone 5 look tacky. This is a wet installation so you have to be careful and have loads of patience when applying it. It took me 1 hour but I'm very pleased with the result. Strongly recommend Phantomzkin. (Special thanks to Blurnard).
ya. . i think if we work physically + putting in jeans or pants pocket, the white silicone might turn colour soon. It happened to my 1st bumper which i have used 2 weeks . . so zz in the end i got the bumble bee sgp case instead zzhaha i hope it wun turn yellow at least when i was using iphone4 with Neo Ex it did not turn yellow after almost half a year of usage....it will probably turn grey by the way i am using it...lolx
have anyone found a transparent bumper case yet ? all the transparent cases are on the same level as the screen, so u cannot put the screen face down..![]()
They have been around for... Very long... I would rather take dataflex than any other spigen sp![]()
where can I find these Dataflex iPhone 5 screen protectors?
Is the high resolution anti glare anti fingerprint sorta like sgp oleo ? never heard of this brand before. interested to try.
that confirm my thought... cause the rim on the sector 5 frame leaves no space to "kiap" the back plate. so should be pasted.....![]()
