when i get my casing of choice, i gonna clean it ... then sell it off for $5![]()
how do i go about cleaning it?
oo wr u going...btw i have decided to build back my hd800 rig....but before i hoot anything i need to make sure i find a perfect match....gonna find somebody wif the spl phonitor-hd800.....then maybe a belcanto dac
sounds like you gonna do a unboxing of Belkin Arm Pouch with photos (video) ?
hmm, i hope your phone is naked ... or super thin casing, or easily removed from casing type without fear of scuffgate
This one fit iPhone5?... coz most i see is for iPhone 4/4S no hole on bottom de.
Thanks more pic if possible...
haha no lah, just peektures nia. im using sgp neo hybrid bumper so easy to remove.
see peektures below for the Belkin armband, mine ish the Ease-Fit Plus version mentioned earlier by Jas007, got mine wib 10% discounts from Challenger...
Armband See Through Compartment
Velcro Strap
Slot on Armband for House Key or $$$ for convenience sake which is the main difference between the Ease-Fit Plus vs non Plus version.
iPhone slot in from the back of the case from the top slot.
There would be a gap at the opening which will not cover the phone entirely.
Earphone Jack opening at the bottom of main compartment.
Velcro strap when closed
Features
- Convenient key pouch
- Lightweight material
- Longer, adjustable strap
- Slim, form-fitting design
- Sweat protection
- Fits arms 12.6”-15.8” (320mm-400mm)
if anyone needs more details and information can refer to this link here.
What is the price of this in challenger?
Looks like it could scratch the back of the aluminium casing if not properly placed as well as the bezel.
hmmm noted.. still looking around for a proper alu bumper style.
if must use a bumper, pls opt for rubbery soft materials as the phone's sides are very prone to scuffing. i saw it happend on my friend's black ip5 when he removed his hard plastic bumper, now he heartpain.
hahahaif must use a bumper, pls opt for rubbery soft materials as the phone's sides are very prone to scuffing. i saw it happend on my friend's black ip5 when he removed his hard plastic bumper, now he heartpain.
Cool... So u not hooting ur speakers liao? I still decided whether wanna start my hifi stuffs... If need to plus amp all this I might not have enuff space... Some more need alot of research, no time leh... unless u spoon feed me with ur research material. Hehe...Which is y tht time I just wanna settle for headphone sound card combo.
Which brand of bumper is that?
Bro tbh everytime i think of hifi i sian bout headphone rig....i can definitely spoonfeed u but i bet many ppl will beg to differ...though i can bring u this weekend to listen to afew speakers then u will understand y i stick wif monitor audio which in my opinion after going thru more than 10 different setups is reasonably priced but very good sounding...for me im not the typical audiophile of vocals classical an thosw stuff....me n my dad play heavy metal thru our systems and it is not easy to get speakers which can rumble....
how about this bro ? patchworksonline.com
Alloy X even has a wood base one.
Korean company, I'm waiting for one of their crystal snap on cases to come out, but saw they have alu bumpers as well sorta like Elementcase![]()
where to get them locally? im waiting for Blade alu enclosures.
