The Samsung Galaxy Note II LTE thread, and we're not trying to overly compensate for anything!
intenn
Could you kindly help me check behind the set which country is it made in? If its made in Korea means same as telco one... I go my Jurong Point Challenger had hoot 1 set... Thanks
Mine at home charging but their demo sets are directly from samsung so i think samsung themselves supply them?
gibson7
mine's made in korea.
there's a sticker/label on the set, take out back cover and look under the battery
Dahawk
note 2 with samsung dock!
Hi bro where did u buy it And how much you?
GamerZ
in the exact same boat as you man. im sure im covered in LTE cos of my bros ip5...
called singtel liao, they will get back to met soon, the checking their backend
same as me, I got 2 lines 1 work, 1 personal, both has 4G VAS. Put the Note 2 side by side with iP5, Note 2 did not show 4G while my iP shows LTE.
tohchr
One question, how is the battery life? Thinking of getting this and sell S3..
tnatna
when we pull the spen out, isn't a list of programs supposed to appear as a panel by the side? or am i mistaken for note 101?
Jumpman23
The program panel at the side is for the split screen app usage, triggered by long-press back button. When the spen is pulled out you the pen related apps panel appears instead.
ProGamer84
this is what i get when i close all my apps, and run a Geekbench
but will hit 2000+ sometime... lol...:s22::s22::s22:
gibson7
Dun ustd the title.
it means that. just because note 2 is a huge kickass phone of a substantial size...
when we are buyibg or bought the note 2...it doesnt mean that we are over compensating in other areas of our life which we may find "small"
gibson7
hmmm...I havent really had the chance to mobitor the batt life. but from the expriences from those at xda... definitely can last 1 full day. some even more.
