avsquare
- Oct 27, 2011
WAHRAOOOOOO.
singtel user here, wonder if it'll be as fast >:
Ask Vulpigs lor, he Sinkdiao 4G user IIRC.
Anyone on Sinkdiao 4G do a speedtest?
WAHRAOOOOOO.
I not using 4G, that time is kope a friend's 4G card to test only.![]()
but was it fast? HAHA
Yeah, is Sinkdiao's 4G fast? Full bar got hit the 72Mbps limit?![]()
dont know should be happy or sad, >50mbps internet connect, with 2gb limit![]()
Dac is only converting digital signal to analog signal. The volume is handle by on chip amplifier. A quality dac is only a part of a chain to produce good sound. Other things like source, amp (resistors, tubes or opamp) and headphone must match. There is also impedance. I have no idea why whenever people saw using a wolfson means good sound quality.IMHO, DAC (digital to analogue converter) is a hardware driver chip that drives the earphone output directly at the audio jack. Of cause you can be right that Samsung is biasing the chip in a way to limit volume.
The S3 uses the Wolfson wm1811 Audio Hubs | WM1811 | Wolfson Microelectronics which is well known as a high quality DAC for mobile device. On paper it does 5.3mW total power for DAC playback to headphones. Not that I blast my earphone, just wondering why it's stuggling to drive my Sennheiser PX100 which is actually relatively easy to drive.
Heng mine is 4+1, consolation prize![]()
EH singtel 12gb plan, activate 4G wont revise plan right![]()
what I understand is once you activate 4G your telco will convert your plan to the equivalent plan.
Like if yours is now the 50++ bucks one, will become the 4G 50++ bucks one, that plan is 3GB cap IIRC.
why other forumers get to keep 12gb with 4G??
thought depends on which telco you are one?![]()
who kept 12GB with 4G?![]()
but its a forumer at the old thread!!!i forget whobut its a forumer at the old thread!!!
High end plan is it? I never heard of this..
now high end plan where got 12gb
i only know he's a singtel user
maybe the CSO made a mistake lol
Im on 12gb plan, 4G network.. LolNo la cannot keep 12GB one when you switch to 4G plan
