N7105 Root and custom rom flashing tutorial (R&D stage)
  • Need someone to talk to?
hosehbo?
Hey guys, may i ask what can i do if i used the Triangle Away and still shows 1?
I rooted the Note 2 that i got from Singtel and downloaded the Triangle Away 2.10, installed it and ran the app. It wasnt able to read the count so i rebooted into special mode and reset counter and device status. After a follow up reboot i go settings to check still see device status as "Modified" and i ran Triangle Away again and it still shows counter as 1.
What am i doing wrong? Some guru can advise?
*Edit* I checked under download mode and i see Custom Binary Download: NO . Does that mean that it has reset the counter?
same thing guys. mine showed as modified too though my binary states 0. previously it was 2 cos i rooted then did the CWM flash.
am i doing this the right way?
another qns is, i read that some bros here manage to get to multi-task with non official apps like whatsapp after rooting. however for mine even after rooting, i still can't multi-task on whatsapp. only the ones that were supported initially.
so am i doing everything right?
hope some gurus can guide me.
jarylw
It will show that way as long as you are not on stock unrooted firmware. If you are trying to claim warranty, just flash stock rom (does not increase flash counter) over it, and you will be golden.
LesterQ
Just download and flash a stock from from Sam mobile. Or wherever.
Flash via odin on the computer..
hosehbo?
thanks for the explanation.
then regarding the multi-tasking feature, am i the only one facing this issue or is it normal to not be able to multi-task while i'm using whatsapp even after rooting?
thanks
gibson7
it's normal. so far i've only seen one here reply saying he got that function of adding other apps there. but no screencapture of whether is it the same as what we were referring to.
eijnaix
Can provide a link to download a stock firm.....i try searching via samsung.com.sg but only got manual download. No firmware to flash...
Webbyboy
Sian, i need to unroot in order to get updates?
jarylw
What's the latest firmware update atm?
EDIT: What Build Number does it show in Settings -> About Phone?
